Connecting controller to spark problem
4656 9 2018-8-4
BjP0420
I just purchased a spark and controller separately and cannot get the controller to sync.  I activated the drone and it works with my phone but syncing with the controller does not work.  I’ve went through the process 10 times and the controller just beeps once and nothing happens.  Is there an activation process for the RC I’m missing?  When I turn on the RC there is no WiFi from the RC showing on my phone, I’ve tried turning airplane mode on and off, still no WiFi from the RC.  Should the app recognize that there is a remote present? How do you check the software on the RC?
2018-8-4
Joller79 DK
Flight distance : 26447 ft
Denmark
Rc should show up.. I did the manual sync a few days ago..turn on spark, wait a minute till it is done booting p, then hold power button till ypu hear one beep and release(3sec). RC you hold both function buttons and the pause button i believe, u til it is beeping.
2018-8-4
Joller79 DK
Denmark
2018-8-4
BjP0420
Thanks for the quick response, unfortunately I’ve tried that a bunch of times and nothing happens.  I don’t think the RC is transmitting a WiFi signal.  I’ve tried to connect it through the app when it asks whether you want to connect to just the drone or the drone and the controller, and my phone just says cannot connect to RC-ae68w
2018-8-4
DJI Paladin
Flight distance : 318 ft
Sorry for the inconvenience.  May I know the current firmware version of the remote and the aircraft? Are you using android device? If yes, did you try to use OTG cable? What is your current DJI Go 4 app version? Kindly follow the video tutorial below on how to properly link your remote to your spark.
2018-8-4
BjP0420
I have tried the second way of connecting in the video with no success.  Have not tried the first method because the controller WiFi does not show up on my phone, or my iPad.  I’ve tried turning airplane mode on and off but still nothing from the RC.  The WiFi from the spark does show up.  I am using an iPhone 6 and I’ve also tried my iPad Pro.  I do not know the firmware version for the RC because it’s never been linked to anything.  The firmware version for the spark, I’m not sure how to check.  When I connect the drone it says “latest version” and I’m using the DJI GO 4.0 app
2018-8-4
DJI Tony
BjP0420 Posted at 2018-8-4 08:50
Hi, thanks for the response, may I know where did you purchase the unit? I'm afraid that the RC needs to be in service for further evaluation, however, if any case that you bought the unit in re-seller you might try to contact them first to see if you could replace the unit. Please see the link below if you need to contact our support. Thank you.
www.dji.com/service
2018-8-5
BjP0420
i purchased it from Best Buy.
2018-8-5
DJI Stephen
Hi. Thank you for the additional information. The best thing you need to do is contact DJI Support at www.dji.com/support for further assessment and repair of your DJI Spark's remote controller. Thank you.
2018-8-5
tchappell
I have the exact same problem for my new Spark and RC.
2019-6-27
