TimDerLauch
Facts
16.4.18 - Computerbild
Pictures of the alleged Phantom 5 turned up !
A grey DJI drone with interchangeable lenses should be the Phantom 5 !
The lenses should have the focal length 5, 24, 35 and 50mm.
Other specs :
max. Speed : 88km/h (15km/h faster than the P4P !).
weight : 1,8kg (0,4kg more than the P4P).
flight time : 33 minutes.
price : 1600$, ~1300€
Pictures : Drone , Gimbal , Completly
Is this a real leak ? No - see next part ! | 24.5.18 - Golem.de
The alleged Phantom 5 was just a special delivery !
It was a modified Phantom 4 Pro !
5.6.18 - myfirstdrone
A few drawings are leaked !
The Gimbal & camera , the obstacle avoidance , other
Battery
The battery should be a new type of Lipo batterie, with a lot longer flight time and also a lot longer charging time !
And also, more expensive !
Obstacle Avoidance
The new P5 should have a 360 dagree sensor system.
That is very important because the weight should be about 8 pounds and should be about 55mph (88mph like the first leak !)
Motor cooling hole
The new Phantom 5 should also move the cooling home to the bottom of the drone ! So, it is rainproof for movie makers !
Weight : 8 Pounds.
max. speed : 55mph
Are the pictures real ? Maybe !
What we think :
Weight : 8 pounds
This isnt realistic !
Speed : 55mph
It could be possible !
From the community :
By Labroids :
weighing in at around 8 pounds and being able to go 55 mph
An 8 pound Phantom ??? I don't think so.
All that anyone knows is what can be seen in the photos of the prototypes
Interchangeable lenses were leaked in march ???
No ... it was back in November.
Thank you, Labroids for your help !
So, what do you think, what do you know ? Post it with a source and I will add it !
