Zenmuse X5 going crazy
974 8 2018-8-6
andrevan
Flight distance : 10138 ft
Can anyone explain what happens here and suggest what to do? Same problem when mounted on the Osmo. Started occasionally under startup procedure. Now it happens everytime and won't stop. Hoping for answers.
André
2018-8-6
andrevan
2018-8-6
andrevan
See
2018-8-6
DJI Wanda
Hello there. We apologize for the inconvenience. Did you try to remount the camera? Did you try to calibrate the gimbal and restart the aircraft? Did it suffer from hard landing?
2018-8-7
Des_B
Flight distance : 129600 ft
Hi Andrevan,
I had something similar happen. I cleaned round the rectangular multiway connector on the gimbal with a clean artists paint brush, and the fault cleared.
Regards
Des
2018-8-7
andrevan
DJI Wanda Posted at 2018-8-7 00:43
I haved tried to remount the camera several times with no result. No hard landings or chrashes. Will try to recalibrate the camera. Thank you!
2018-8-7
andrevan
Des_B Posted at 2018-8-7 08:26
Hi Andrevan,
Thank you, I will try that to. Did you use any chemicals in the cleaning process?
2018-8-7
DJI Wanda
andrevan Posted at 2018-8-7 22:28
Alright. Let us know if you still need help.
2018-8-8
Des_B
No,
just brush and blow.
2018-8-8
