CRdroneflights
Costa Rica
Same problem with my Mavic Pro. I'm using the DJI Assistant 2 to update firmware but it is taking a VERY long time. I've aborted and re-started several times -- to make sure the laptop doesn't go into sleep mode or anything. Once, I got to the end of the update process but received a message saying that the update failed because the drone battery was less than 50%. I'm now into my 4th update attempt, and 35 minutes into it. The DJI Assistant 2 says that I'm 46% through the process and the drone batter is about to fall into 75% power (3 solid green lights, one flashing green light). Doesn't look like I will make it before the battery drops to 50%. This is crazy. Any suggestions? |
