Lost control of Spark
868 5 2018-8-7
fansc5292e4f
Flight distance : 18622 ft
Mexico
Hello guys,
Last weekend I was flying my spark and when I had about 30% of the battery I pressed the return home button.
It started coming back and suddenly it started spinning around, I had no control at all (the drone was calibrated, the software was updated and there wasn’t wind that could’ve made it move like that). It was very high and while spinning it touched the ground (luckily is was grass).
Once it touched the garden, automatically started flying again and I regained full control. I examined and it seems in perfect conditions.
I’ve tried flying it again and it seems ok, but I’m scared to fly it in different condition in case that happens when I’m over water or somewhere hard to get .
Has anyone experienced something similar?
Thanks
2018-8-7
Yiye88
Flight distance : 192625 ft
Yes, right here. also My Dji Spark jumps up and down when taking off. Sometimes, while flying there is a delay signal from the control to the aircraf of about ten seconds to react to the command. When landing it does not go all the way down to the ground on command, it waits about 10 to 15 seconds hovering near the ground before landing. someone please help.
2018-8-8
Yiye88
2018-8-8
DJI Stephen
Hi there, Sorry for the Inconvenience that you faced regarding with your Aircraft. when flying your Aircraft make sure there is no Interference on the area that will interrupt the signal from the Remote to the Aircraft and also make sure you have enough GPS. If ever you encounter it again I would suggest to send it in for further checking and have a Data analysis as well.
2018-8-8
Ahmed Hussain
Flight distance : 1339761 ft
Kuwait
This is because either a previous crush or need to check the props.
One more issue to be checked is take off test both auto and manually, only take off and hovering. find out the difference which is better!
EDit: I am talking about the abnormality. But regarding to stop landing before 2-3 ft that is normal for more conformation.
2018-8-8
BeastMaster_101
Flight distance : 1082992 ft
were the props  fully secured?
2018-8-8
