Michael Starley
Flight distance : 2812 ft
Process of elimination. Visually inspect all vibration dampeners. Replace if bad. Then remove props. With the phantom powered off spin each motor and listen for any noise. Clicking.Loseness,or just debri in the motor bell itself. Check each and every fastener. Tighten if loose.
Balance props.
Connect to P2 assistant program. Place the bird on a level surface.(Critical) Perform IMU calibrations. All of them.
After that connect remote control to RC assistant. Calibrate remote.
After that,reconnect quad to P2 assistant. Calibrate quad.
after that. Find a place without metal or magnets,(Empty Pockets Of Cell Phone,Keys,Change), I think you catch my drift. No metal at all near quad.
Then do compass calibration.
Hope that helps. Good luck man |
