CS 785 misprint in "Offline Map"
747 8 2018-8-10
Polet999
Flight distance : 352359 ft
I have very bad experience with CS-785 since i bought in September 2017. DJI replaced my unit few times (reboot during the flight, backlight shot down)
Now is a new issue, misprint in "Offline Map". CAS-1939730-Q6Q4C5. Even DJI replaced CS again the problem persist. In two month with five different  technicians  there best advice "Factory Reset", but it's not solve the problem. In my understanding that firmware should be update. Write who else has this problem.
CS unfortunately very unreliable DJI product.
https://youtu.be/CoRpxxth9p4
2018-8-10
nixuspix
Flight distance : 2864974 ft
Latvia
To fix the problem with naming  the offline maps just turn off Auto correction , next word suggestions , show correction suggestions  in the crystal sky settings under language & input -Android keyboard
2018-8-10
Polet999
nixuspix Posted at 2018-8-10 22:53
I did this before, changed to "Modest" & completely "Off". Its not solve the problem. See attached photos when I try print Germany
2018-8-11
nixuspix
Latvia
Also you can try to press "Backspace" after each typed letter
Besides "Autocorrection OFF", also
2018-8-11
Polet999
nixuspix Posted at 2018-8-11 06:11
Hi nixuspix,
First-before you respond, did you try by yourself if it's working?
Secondary-I've never heard more foolish advise, instead to fix keyboard problem of misprint to
use Backspace. By the way Backspace also not working. I tried four different CS785 & ALL of them have this defect. Can you imagine if Apple or Samsung have this type of problem? Of course NO. Because before they released to the market new model THEY are tested
DJI must fix the problem ASAP.
2018-8-11
Polet999
Polet999 Posted at 2018-8-11 14:58
Hi nixuspix,
2018-8-11
nixuspix
Latvia
Sure both methods are working fine for me and for many other here in the forum if you try to search about this problem. It' s clear that both suggestions are only workarounds and DJI has to fix this in principle.
2018-8-11
Polet999
nixuspix Posted at 2018-8-11 22:34
Don't mislead that is "working fine" & hide the problem.
Please provide video  to print 'United States' in "Offline Map", with your "two methods" without editing.
I agree that DJI has to fix this issue in principal ASAP
Why DJI broght to the market "so raw" product without complete testing?
Customers feel uncomfortable with so expensive SC & waste time to conducts testing for DJi.
2018-8-12
Polet999
Polet999 Posted at 2018-8-12 13:39
Hi nixuspix
Please be remind provide video link how you print name of the country in "Offline Map"
2018-8-17
