Mullheliflier
Flight distance : 12305135 ft
The Go 4 App will show you the battery voltages. You can see if a cell is different to the others. It may be worth running the battery as low as you can get it and let it cool and charge it again. Fly it in the aircraft until it will no longer fly, just a foot or so off the ground once the battery goes down. Cancel the battery warnings. I have an Inspire 1 and it will tell you when to do this with its batteries. Good luck, I hope it fixes it. Also check that it has not puffed. If it has I would not use it. |
