Inspire 1 Camera Upgrade
6197 10 2018-8-11
fansf6db00ae
Flight distance : 334360 ft
Hi Guys...I have two early version Inspire 1's and they fly great so I was thinking about upgrading to a better camera (both have the X3 now).  What camera would you guys recommend for reliability and quality performance.  I understand I would need a larger vibration plate and landing gear extensions.  And secondly how would I handle the camera firmware updating?   Here's is a list of the firmware updates I have loaded now:
        APP                                              3.1.42
        AIRCRAFT                                     1.11.01.50
        REMOTE                                        1.7.80
        CAMERA                                        1.10.01.40
In my business I take photos and videos for small and medium size businesses as requested but I have been asked about mapping so that's a consideration.  Can't get an Inspire 2 right now so I am even considering different cameras on each bird.   Thanks
2018-8-11
dpeagle
you only have 3 options ( z3, x5 & x5r). the z3 is the same camera basically as your x3 with a digital zoom feature. the x5 & x5r will require the vibration plate on your v1. when you consider the cost of the x5 and the reduction in flight time vs the ability to change lenses (that need to be balanced) & the improved (albeit , small) picture quality for still images, imo it's a waist of money. the only true upgrade to the camera system on the i1 is the x5r, but with a cost over $2000usd new, you could almost buy an inspire 2.
2018-8-11
fansf6db00ae
dpeagle Posted at 2018-8-11 13:34
Thanks for the very helpful information.
2018-8-11
rwynant V1
Flight distance : 4842277 ft
The P4Pro with the 20mpxl camera and all the settings that can be changed to your needs for Real Estate as well as Mapping.....that's a $1500 bill + extras.....but it's the whole enchilada!!
Flight time on the Inspire will be 15 min tops with a heavier cam......the P4Pro is 28 min flight time......ish
Randy
2018-8-11
fansf77370fb
Flight distance : 1008924 ft
I like the Z3 much better than the X3.
2018-8-12
fansf6db00ae
rwynant V1 Posted at 2018-8-11 16:36
That's a very real possibility that I hadn't thought of.  I could sell one of the Inspires and still upgrade my  (fleet).  Thanks Randy
2018-8-12
fansf6db00ae
fansf77370fb Posted at 2018-8-12 03:50
What are the differences?
2018-8-12
fansf6db00ae
fansf6db00ae Posted at 2018-8-12 04:04
I think I understand the differences.  How do you rate the Z3 for reliability?
2018-8-12
DJI Wanda
Hello there. Thank you for reaching DJI Forum. The compatible gimbal cameras for Inspire 2 are ZENMUSE X3, ZENMUSE X5, ZENMUSE X5R, ZENMUSE XT, and ZENMUSE Z3. It will really depend on your needs or the purpose of buying a camera. You may try to compare them each here: https://www.dji.com/products/com ... ndsite&from=nav
2018-8-13
fansf6db00ae
DJI Wanda Posted at 2018-8-13 09:47
Hello there. Thank you for reaching DJI Forum. The compatible gimbal cameras for Inspire 2 are ZENMUSE X3, ZENMUSE X5, ZENMUSE X5R, ZENMUSE XT, and ZENMUSE Z3. It will really depend on your needs or the purpose of buying a camera. You may try to compare them each here: https://www.dji.com/products/compare-zenmuse?site=brandsite&from=nav
Thanks Wanda
2018-8-13
DJI Wanda
You're welcome. Please let us know if you still need anything.
2018-8-14
