Bad video and long lag time on Huawei tablet
1147 15 2018-8-12
dreaminweavers
Singapore
Hello all,
I am brand new to drones.  I have a really interesting and frustrating issue happening.  I have a Samsung S7 that works perfectly with the DJI Go 4 app.  I wanted to try and use my tablet for the bigger screen and to spare the battery of my phone.  So, I loaded the DJI Go 4 app only my Huawei mediapad, and it works horribly.  The video on the tablet screen is super chopy in the go fly mode (see video link), and there is a really long lag between when the camera sees something and when it shows up on the tablet screen (maybe 10-15 seconds later).  I guess I should be thankful that the phone works properly, but if anyone has seen this before or has any idea what to do, it would be appreciated.
https://drive.google.com/open?id ... zp_NNBIRwo6MtkZEnWQ
Thanks
Don Weaver
2018-8-12
msinger
Flight distance : 228255 ft
The tips in this article will help you ensure both your tablet and DJI GO are setup to run as efficiently as possible.
2018-8-12
DJI Gamora
Hi, thanks for reaching DJI Forum. We do apologize for the troubles. Unfortunately, Huawei mediapad is currently is currently not on our supported list of devices. I will be posting some of the supported mobile devices below. But don't worry i will be forwarding this concern to our engineers for future enhancement. Thank you.
2018-8-12
jmb63
Flight distance : 7009439 ft
What are the specs of that tablet ( CPU/Ram) ? Your video looks like a problem with the actual power of the tablet. As posted, try reviewing the suggested article to optimize the tablet. Depending on the version of the DJI app you NEED at least 2 GB of ram and an octa-core processor or a fast quad-core to run the DJI app!
2018-8-12
Macaulayjuan 4
Flight distance : 865469 ft
My experience - purchased a new Asus tablet just for my DJI aircraft and suffered at least a 1second+ latency. (my android phone worked perfectly) Returned Asus tablet and purchased an iPad mini 4, problem solved. Not an Apple fan and not trying to stoke the never ending android/ios debate. Just relating my experience.
2018-8-12
S-e-ven
Flight distance : 5922034 ft
Thailand
I'd say that is not performing well. Try if it gets a bit better with OTG, but I also would say: The specs aren't good enough
2018-8-12
dreaminweavers
jmb63 Posted at 2018-8-12 06:10
definitely, not the tablet.  It is brand new.  Octa Core (4 x 2.3 Ghz + 4 x 1.8Ghz), 4GB Ram, Android 6.0 Marshmallow
2018-8-13
S-e-ven
Thailand
ouch, I expected an older one.
Android 6, try Go4 4.1.15 for some tests. And a otg connection!
https://www.apkmirror.com/apk/dj ... o-4-4-1-15-release/
2018-8-13
jmb63
dreaminweavers Posted at 2018-8-13 05:11
Ohh...well, that should be plenty to run the app...
Did you try the "optimizations" suggested above?
Use the tablet in airplane mode?
Disable or uninstall anything not need for flying.
Also, some tablets have a built-in option that will, by default, try to optimize the program/app for battery or data purposes. Maybe look into that?  That might not play well with the DJI app.
2018-8-13
dreaminweavers
msinger Posted at 2018-8-12 04:14
Unfortunately, I went through all of the setup steps outlined in the article.  No success.  Same Issue.  Looks like it is a compatibility issue with the Huawei Mediapad .  Here is to hoping that DJI comes up with something soon.  Not going to go out and get another tablet just to fly.
2018-8-13
dreaminweavers
2018-8-13
dreaminweavers
S-e-ven Posted at 2018-8-12 08:16
forgive the ignorance.  What is OTG?
2018-8-13
S-e-ven
Thailand
dreaminweavers Posted at 2018-8-13 05:41
USB on the go, cable connection
Do you have a otg adapter, somewhere?
Together with your charger cable, you have a OTG connection.
For testing it will be enough!
Plug the micro USB from the adapter INTO the RC
usually AFTER you have pluged the other end into the Tab /device and the LED from the RC is steady
Go4 app shoul'd tell "connected", after it asked you to "open always if ...."
If the Spark is on, "Go Fly" should show up.
2018-8-13
jmb63
dreaminweavers Posted at 2018-8-13 05:39
Your tablet should be able to power right through the DJI app!
There is something (app or system function) running on the tablet that is affecting the app.
Did you try the suggested install of an older version ( I personally use 4.1.15 ) of the DJI app?
2018-8-13
dreaminweavers
Problem solved.  Putting the tablet in airplane mode seems to have resolved the issue.  Haven't flown yet, but all of the symptoms are gone.  Thanks for the help everyone.
2018-8-14
msinger
dreaminweavers Posted at 2018-8-14 04:46
Good to hear!
BTW, that was suggested in my article
2018-8-14
