Oscarfer30
Flight distance : 7756 ft
Chile
Hard to look, will try to explain
1- No GPS mode to fly, drone did not pick up enough sats to lock his position, therefore goes to ATTI mode.
2- ATTI Mode uses the drone "belly" cam to take ref pics of the floor and, with this, avoid the drone drifting. In this case, this does not work as you are flying AT NIGHT
3- Drone are not able to locate himself using GPS, switched to ATTI mode to avoid drifting and no luck because probably was too dark ...
4- Last thing is the issue with the compass. Before take off you receive the error "calibrate compass" .. so with all those errors and flaws prior to taking off, you where never take off this day.
5- Seems like no knowledge to fly, since you take the shortcut to all of those "details" and take off ignoring those warnings and best practices.
Sorry to be a jerk, but those machines are very complex and surely there are not toys. Ignoring the basic facts on how to operate your drone would for sure ends in a crash.
