lens
1144 7 2018-8-13
Drone 4K
Hi,
what lens can we put on the Inspire ? x5s ok but can we put Z30 and other model for matrice 200 -210?
Thanks
2018-8-13
Keule
Flight distance : 3733015 ft
You can put the X4S, X5S and the X7 on the Inspire 2.
Cameras, such as Z30, XT or XT2 are only working with the Matrice 200/210 series.
2018-8-13
Drone 4K
that is so sad but im pretty sur they can put the X7 and X5S on matrice but for us ...... so sad
2018-8-13
DJIJAKOB
Flight distance : 740577 ft
Norway
Drone 4K Posted at 2018-8-13 04:37
The X5S can be mounted on the M200 Series. The X7 cannot, this is due to the fact that the X7 uses the Inspire 2's internal processing. The M200 would simply not be able to process the material from the X7. And after all Inspire 2 is meant as a cinematographer platform, while the M200 Series is an enterprise product.
2018-8-13
Drone 4K
you can do thermal with  inspire 1 and not 2 , seriously you can do more then cinematographer with inspire one ......
2018-8-13
DJI Wanda
Hello there. Which specific model of Inspire are you referring to?
2018-8-13
Drone 4K
im referring at Inspire 2 . I made a mistake in my last post , you should read You can do more with Inspire 2 (not inspire one) than only cinematographer ....
2018-8-13
DJI Wanda
Drone 4K Posted at 2018-8-13 10:15
Thank you for the response. The cameras that are compatible with Inspire 2 are ZENMUSE X7, ZENMUSE X5S, and ZENMUSE X4S. For Matrice 200-210 are ZENMUSE XT2, ZENMUSE Z30, ZENMUSE X4S, and ZENMUSE X5S.
2018-8-14
