Matthew Chirico
Flight distance : 769160 ft
I need some serious guidance in Adobe Premiere when exporting drone footage. I’ve been editing for a while now but usually just wing-it on the export screen. I’m not too knowledgeable on what everything ACTUALLY does to the footage or which settings should be toggled to make it look more crisp, as opposed to decreasing its overall look. For example, which Profile (High, Main) to pick or Bitrate (CBR, VBR 1 Pass, VBR 2 Pass) target and max.
For example, I recently used my Mavic Air to get some 4K footage and created an edit in Premiere. I rendered the footage in the program and it looks great. Then I go to export and it’s skippy/laggy. If you guys are well versed in the export settings area of the program and what makes a video look smooth/crisp, what should my settings be?
These were my export settings:
Format: H264
Video Dimensions: 4K
Field Type: Main, 4.1
Progressive
VBR 2 Pass
Target Bitrate: 80
Max Bitrate: 100
What am I doing wrong to have my exported video be skippy/laggy?
Are there better export settings anyone is aware of that work best with 4K footage at 100MBPS from the Mavic Air?
I mainly use my Mavic Pro, but it’s out of commission for the time being. What are the best export settings for that as well? |
