FTrindade
Flight distance : 395456 ft
Portugal
amanda.k.ryan1087-sp Posted at 2021-4-1 03:47
I had to play around with the joint angle by moving the joy stick ever so slightly to get the numbers across the board near zero and def below 1. Then when you have a good set of numbers you press joint angle on the screen and a secret menu pops up. You have to hold for a at least 6 good seconds. Then when the menu pops up click ok. It will reset the joy stick reading on channel 3. I figured it out last night. I know this is late in the game but I hope this helps everyone with the problem!
Had the same issue.
Today, after reading this thread, applied the joystick calibration, then the joint angle calibration suggested by @amanda.k.ryan1087-sp above and then align the joystick again and bam.. no more issue!
Thank you so much, everyone!
