DJI GO 4 V.4.2.24 Available now for Android.
114878 114878 2018-8-14
小仙女的星巴克
Flight distance : 4657841 ft
I just updated to 4.4.24 on my S8 plus and Mate 10 Pro. Hope it's fixes some issues.
https://www.apkmirror.com/apk/dj ... droid-apk-download/
2018-8-14
DJI Natalia
Hi there, thanks for choosing DJI. If you encounter any issue with the latest firmware, please let us know. We are here to help. Thank you.
2018-8-14
Canefan
Flight distance : 88074 ft
Not on the Playstore yet.
2018-8-14
小仙女的星巴克
It's usually take a few days later for it you appear on Playstore.
2018-8-14
rolling56
Flight distance : 138310 ft
What does it fix? N/M they never mention what really gets changed. The DJI SDK is what needs to be fixed amongst other things.
2018-8-14
MrArcher
Flight distance : 401706 ft
With the severity of flaws found in 4.2.20+ so far, you would think we'd see one heck of a detailed change log.
2018-8-14
Paul_IA
Flight distance : 4959019 ft
"DJI releases are like a box of chocolates. You never know what you'll get".
~Forrest Gump
2018-8-14
dbparti024
Flight distance : 3343 ft
Im curios if they addressed the video lag and pixel problem. DJI needs to test more Android devices.
2018-8-14
Ethan80
Flight distance : 295 ft
changelog?
2018-8-14
davidmartingraf
Flight distance : 108805200 ft
I don't see it on the Google Playstore.
2018-8-14
Asainz320
Flight distance : 1397858 ft
All changes are for the Inspire 2
2018-8-14
Asainz320
These are the changes
2018-8-14
Asainz320
I guess the screenshot didnt get attached.
Whats new:
Inspire 2:
- Supports distinguishing between master and slave functions for the Cendence custom key.
- Adds a click to focus function in full-screen mode.
- Adds a parameter setting function for gimbal roll axis.
- Reduces information prompts in slave mode.
- Adds a new function where you can recenter the gimbal or move it downwards with the custom button.
2018-8-14
MrArcher
Just showed up. I wonder if anyone has tested this version yet?
2018-8-16
Optimus_Prime
Flight distance : 597218 ft
Vietnam
Have just noticed me to update, will test it today.
2018-8-16
nnote
Flight distance : 1358048 ft
I just tested it on my Nexus 6P. Now, granted I'm in my house.
I was on DJI .12 and the Mavic on the latest firmware and video was horrible. I haven't used my Mavic in months. I fired it up and walked around the house and got the typical video pixalation.
I updated to the new DJI GO and fired it up. NO pixalation but an occasional stutter with an occasional lag. This was walking around my house with the mavic in hand.
Haven't flown yet, but if this is how it is when I go fly, I think we MAY have a 95% resolve.
I have no faith, but atleast what I've seen so far, I may have a usable Mavic again?
2018-8-16
miketmtpro
Flight distance : 1883940 ft
I flew earlier this evening along with a few others at the RC field.
Prior to that, decided to test this fully. Uninstalled 4.2.12, and installed a clean 4.2.24. Also updated fw to .0400
On my  Gal Tab S3 820 the video seemed much improved. No disconnects.
On My Note 8, very good as well (that was fine before anyway).
Others there tested on an Iconia Tab. It seemed ok, a couple blurbs of video flicker here and there, but no pixelation. That one was pretty bad before.
Zen Pad 10- same as above. Slight jitter, but clean.
Samsung Tab A 10.1- much improved and no pixelation.
Nvidia Shield was ok too.
So far seems ok. Not 100% but flyable. I'll run a full test of 4 batteries and long flights over the weekend. If it passes those tests, then DJI did the Android user groups a solid.
2018-8-16
gertjan_bos
nnote Posted at 2018-8-16 20:18
Thank for your update.
I will keep my older firmware for now till i hear more positive messages.
(Also Nexus 6P)
2018-8-16
Wachtberger
Flight distance : 261509 ft
At the latest the week after next we shall get another new version which will include the Mavic 2.
2018-8-16
GDL
Flight distance : 2768694 ft
Singapore
You sure there will be no more delay for MP 2
2018-8-16
Synopsis
Romania
Hello there,
Probably I'm a noob or the  latest update it's  a failure.
Yesterday, after I update the app ( I use an Ipad Mini 2 non-gsm), my drone has stuck up in the air for 20 seconds, losing all the transmision, (video feed, controller, etc.) even the return home button dosen't work.
So dear DJI Support departament, when you gonna realease a new firmware update for the Mavic Air?
2018-8-17
Charissa
Flight distance : 689334 ft
South Africa
This will be the only time I will update without thinking about it (where DJI is concerned. Reason being, that the previous software gives me so much hassle, that even if this version does not work, I won,t miss out on anything.
I see that even DJI don,t mention the Mavic Air in any of their updates. You don,t see, for drones such as the Mavic Air......wonder why, don,t they think they can fix the problem MA,s?
2018-8-17
hallmark007
Flight distance : 12400594 ft
miketmtpro Posted at 2018-8-16 21:13
Cautiously positive so.
2018-8-17
MrArcher
Hi Mike,  thanks alot for the feedback.  With this, I think I'll install 4.2.24 and give it a short and very cautious try.  After the last two disastrous revisions, I have settled into 4.2.16 very nicely. So, if I see the slightest issue, I'm going right back.  I'll circle back when it stops raining. Thanks bro.
2018-8-17
Amjad1983
Flight distance : 310489 ft
United Arab Emirates
I Feel MA is humiliated  as still there is no new firmware
2018-8-17
0Kajuna0
Flight distance : 267126 ft
Thanks for giving us hope. Will hopefully test and report in a couple of days.
2018-8-17
Cineasta83
Flight distance : 55738 ft
DJI Natalia Posted at 2018-8-14 10:26
I can´t remember when I became a employee from DJI. I'm a beta tester from the company? If so i will give you my Bank account number to recive my salary. If I bought an expensive product, I expect a good support and after-sales service that justifies my investment. Besides that, the product must hold to his promise.
2018-8-17
MrArcher
Cineasta - I don't think getting snarky with a low level forum moderator is going to give you much mileage.  Call DJI, ask for a manager and let them know how you feel.  I mean, the mods here don't even take the time to delete spammers, so do you really think your post here is going to accomplish much? Thank about it.
2018-8-17
Datree
Flight distance : 21371 ft
Downloading this on PIXEL XL and Galaxy s7 i hope the app stops crashing
2018-8-17
djiuser_iTYmGJ1Ipw3c
Flight distance : 6766027 ft
I just came back from flying around with my MA, and I have to say I'm impressed with this new version. At least on this flight I got no motor warnings, good transmission, very smooth image overall (on my Lenovo tab 3 ), and no loss of communication for up to 2000 feet distance. This is just one flight I will have to see after I test this further in other areas, but at least there's hope we have something good. If it continues to work well please DJI leave it alone!
2018-8-17
samgawthorpdji
So even though the MA isn't mentioned as a compatible device (perhaps an out of date list much like dji's own compatible devices recommendation s) it seems to have started to at least potentially iron out some of the issues so many of us have encountered?
Might download it on my new phone and try it and keep older versions on my older device.
2018-8-17
Optimus_Prime
Vietnam
I have refresh firmware on MA, factory reset, recalibrate imu, compass.. and using latest dji go on my s7 oreo. I am happy with the update, no image glitch, range of flying still short but good image transmission, compass calibration did not appear successful. Four batteries and recharge them now.
2018-8-18
nixuspix
Flight distance : 2864974 ft
Latvia
djiuser_iTYmGJ1Ipw3c Posted at 2018-8-17 17:00
Thank You for your report. Now am waiting for update on my CS
2018-8-18
hallmark007
Optimus_Prime Posted at 2018-8-18 03:26
Good job, pleased it’s working well now.
2018-8-18
hallmark007
Hopefully all tests will go well. Good job.
2018-8-18
miketmtpro
4 flights in, and the video transmission is working again. There is a slight what seems like a frame jump during yaws, but pitching is ok, gimbal movement good, and straight flights the feed is like it was when I bought it.
4 of us at the RC club really tested it by running the tablets in HD feed and the video was good. On devices with more ram it was better. If you have a device that is lower in ram, set to Regular mode. If you have a device 4G ram or higher, then you can opt for HD mode. Even caching to device in HD mode was ok.
Next, I reset the phones and tablets to their normal stock settings. Animations on 1x, not disabling backrunning apps. Amazingly they still worked. I expected a mess, but other than a tad more latency, the video feed was not interrupted and NO pixelation was present.
Next is to fly in my urban surrounded  park, and see if any local interference interrupts flight. At my home, I ran it up and down the street, and around utility lines. A couple times I was given strong interference warnings, but nothing in telem loss, or video feed issues. Seems ocusync mode is behaving as it should.
This again is updating all firmware, and the latest Go4 app for Android.
My Mini4 otoh still does oddball things with latest round of iOS app. Still getting zebra bars and chopped blocks at times in flight. Exposure Warning disabled, but seems to kick in at times. Not all the time, jut on occasion.
Galaxy Tab S3 820, Note 8, Iconia, Zenpad 10, Zen 3S, Shield, YDZB 10 4G was the cheapest $120 tablet that worked. Asus TF700, TF300 rooted with A6.0 also worked.
We have other devices to test as well and see how they do. All of these devices failed on 4.2.20, 4.2.21, but have been restored to "working" with 4.2.24
Some have S4's coming in, and we will test on those as well. I have a Note 9 512G, 8G ram phone coming soon, so I'll report on that as well. One of the most powerful devices our company is using along with S4's for field techs, so we'll see how those work on Go4 soon enough. S4 is supposed to have a 790 nit screen compared to 720 on the S3. Slightly larger size will give it a bit more brightness.
2018-8-18
小仙女的星巴克
Great testing!I still have no chance flying outdoor. Too hot out there. But I have tested indoor OPTI mode hovering without issue. Tested devices are S8+ and Mate 10 pro.
2018-8-18
miketmtpro
小仙女的星巴克 Posted at 2018-8-18 07:04
We have some Huawei M5, Lenovo, LG, LLCORP, Dragon and other unbranded as well as real cheapo Android tablets we'll test later this afternoon.
2018-8-18
MrArcher
I just got done with a quick test flight with the MPP on 4.2.24 and it ran good on my Tab A. I didn't trust it enough to go very far, but it didn't skip a beat. I'll try to go a little further out next time as I build confidence again. Nice to see. Thanks DJI.
2018-8-18
HedgeTrimmer
miketmtpro Posted at 2018-8-18 06:48
Not in anyway trashing or putting down all you and your clubs testing efforts.
Customers should NOT have to test DJI's software (Apps, Firmware, Programs, OS).
2018-8-18
