Marcusa
DJI Wanda Posted at 2018-8-15 09:26
Hello there. We apologize for the inconvenience. I just want to confirm, are you referring to Osmo or Osmo Mobile 2? The size of the mobile device mount is 116 x 30 x 34 mm. The Osmo can comfortably hold 5.5-inch devices. The Osmo Mobile 2 supports smartphones 58.6-84.8 mm wide and up to 8.4 mm thick.
good afternoon, i don't know the exactly dimension but in manual balancing the body of smarthpone touch the rear screw, i need max extension in the down side for vertical balance, , after do it i try to rotate the smarthpone and it touch the screw so i can't stabilizy correctly my osmo mobile 2 in manual mode, in automatic mode i can stabilizy the osmo, but i think the motor can't work well for stabilizy the smarthpone, i have another question...i'm trying to update the osmo FIRMWARE but it say FAIL TO OBTAIN FIRMWARE INFORMATION...
THANK YOU
Marco |
