XhakaLacca Boom
Hi
I have a Mavic Air and Samsung S8+ and having some issues using the DJI4 app due to the mobile resolution. The Samsung has a hidden menu that you can decide if you want to appear if you swipe up or pin it to the bottom (or side) or an app to always be present. However I have been trying to do it on the DJI4 app but I cant see a way to pin it.
What it means is that at times you are trying to use the left-hand screen buttons such as land, take off etc but can then accidentally bring in the samsung menu. Then there are times when you have the app open and you want to either go to the home screen, open another app or just close the DJI4Go app, but again it can be hard to bring up the menu without hitting the other buttons like land etc.
In addition, the X to close the app on the initial calibration screen is on the top right-hand corner, for the Samsung edge this means the X is actually underneath the phone holding clamp, so you have to open the clamp to press the X then put the clamp back in place. Surely this would be an issue for others with any of the newer type of phones that use the full edge of the screen?
Has anyone had similar issues and had a way to maybe get the app to pin or to adjust the resolution to make the phone work better with the app?
thanks
