Unable to download off-line maps on Phantom 4 Pro + controller
2487 27 2018-8-14
Dronezoom
Flight distance : 1603711 ft
My Phantom 4 pro + has a 1.4.10 Controller version , which seems to be the only one available right now (at least is the only option I have). I can't download off-line maps, I click on it and nothing happens. I already tried to do a factory reset but got no luck. Can you please help me?
2018-8-14
msinger
Flight distance : 183694 ft
This is a known issue. I have the same problem and haven't seen any mention of a fix yet.
2018-8-15
DJI Wanda
Hello there. Sorry for the late response. What is happening when you're trying to download offline maps?
2018-8-16
Dronezoom
DJI Wanda Posted at 2018-8-16 10:18
Hello. Nothing happened. I click and nothing happened
2018-8-16
DJI Wanda
Dronezoom Posted at 2018-8-16 10:21
May I know what offline maps are you trying to download? Is it the HERE maps or the Amaps?
2018-8-16
Dronezoom
DJI Wanda Posted at 2018-8-16 10:27
Sorry. But whats the difference. Maybe the offline maps that I know its here maps
2018-8-16
Dronezoom
Follow the video
2018-8-16
DJI Wanda
May I know what is the app version of the app? The newest app version of the Phantom 4 Pro RC plus should be 4.2.16, if, on your end, it's APP version is 4.2.6, please upgrade it to the last. You just have to connect the remote to your local wi-fi then the top bar will tell you if there's an update.
2018-8-17
Dronezoom
DJI Wanda Posted at 2018-8-17 01:43
[view_image]
Helo, Follow a new video.
I don t have any updates to make. In DJI website - Download- Have only this update v01.04.01.00
2018-8-17
DJI Wanda
Dronezoom Posted at 2018-8-17 02:35
Thank you. Since you already reset the factory settings and there are no updates showing on the screen, I highly suggest to send it to our repair facility to have a checkup. There might be some software malfunction that causes this problem. May I know where are you located?
2018-8-17
Dronezoom
Brazil
DJI Wanda Posted at 2018-8-17 03:48
Im from São Paulo - Brazil
2018-8-17
Dronezoom
Brazil
I maked many factory resets. But not worked
2018-8-17
DJI Wanda
Dronezoom Posted at 2018-8-17 03:51
Yes, I understand. That's why I highly recommend to send it to our repair facility to have it check. Please contact our support +1 (818) 235 0789 Mon-Fri 7:00AM - 5:00PM (PST)
2018-8-17
P4P+_Brazil
Brazil
Cara vc sabe baixar o mapa da área que vc vai voar né ? Tipo pra quando vc estiver offline poder visualizar ele sem depender da internet.
2018-8-17
Dronezoom
Brazil
P4P+_Brazil Posted at 2018-8-17 04:30
O problema que nao da a opcao de baixar. Se vc ver o video vai perceber quee eu clico r nao acontece nada
2018-8-17
P4P+_Brazil
Brazil
Dronezoom Posted at 2018-8-17 05:11
Sim mas não precisa ser ali, basta estar conectado na internet e visualizar pela tela do controle o mapa da área aonde vc vai voar, com vários níveis de zoom entendeu, que todo o mapa dessa área que você abrir será salvo automaticamente. Quando você estiver offline vai poder usá-lo, as imagens são salvas em cachê.
2018-8-17
Dronezoom
P4P+_Brazil Posted at 2018-8-17 05:26
Ahh entendi, vou fazer esse teste entao meu amigo, voce tem alguma midia? me add no face como Bruno Verzini a minha empresa é a Dronezoom
2018-8-17
Dronezoom
realmente nao funcionou, eu uso bastante  a parte do mapa de satelite, liguei a net e depois desliguei e nao carregou.
Antigamente eu clicava la no mapa e baixava o Brasil todo, agora lascou tudo
2018-8-17
RedHotPoker
Flight distance : 165105 ft
As good as that built in screen may be, the + system seems very limiting to the end user...
RedHotPoker
2018-8-17
Dronezoom
Eu consegui,
Achei na Net uma versao anterior do Radio
https://dl.djicdn.com/downloads/ ... _v1130_20170307.zip
baixei esta versao, coloquei no micro SD e fiz o downgrade para a versao 01.02.01.00 e os mapas voltaram a funcionar.
Como teste eu atualizei tudo e acabou ficando na versao 01.04.01 e realmente esta versao existem BUGS pra nao deixar clicar no Offline Maps. Agora estou voltando com a versao anterior .
2018-8-18
Dronezoom
DJI Wanda Posted at 2018-8-17 04:17
Work with Phantom is my Job, I cant send you the RC. But Finally I found a downgrade version
I maked downgrade to version 01.02.01 and works!!!! Now I hove offline maps
2018-8-18
P4P+_Brazil
Brazil
Dronezoom Posted at 2018-8-17 18:27
Opa vi agora, cara não tenho face, legal sua empresa.
Então não funcionou como expliquei ? Aqui dá certo, faço isso direto de guardar em cachê pra depois usar offline, mas sem dúvida a opção de poder baixar direto um mapa completo é bem superior.
Pelo que você descreveu parece ser de fato um bug das versões mais recentes do firmware.
2018-8-18
GaryNash
Flight distance : 355157 ft
Very disappointing when you read stories like this .. dont DJI Beta test there stuff? Or are the end users expected to do so ?
2018-8-18
Dronezoom
GaryNash Posted at 2018-8-18 03:50
I never see Beta versions, Its possible to download?
2018-8-18
Dronezoom
P4P+_Brazil Posted at 2018-8-18 03:46
tem um video na net do Toms Tech mostrando como funciona o Cache map, a unica opção que menciona Map aki no Plus é para limpar o flight routes. abração
2018-8-18
P4P+_Brazil
Brazil
Dronezoom Posted at 2018-8-18 04:13
Cara não vai em tudo que vc achou como se fosse só aquilo que existe, se postei é porque tenho certeza do que disse, tenho usado como descrevi há alguns meses com sucesso, basta abrir e navegar no mapa que salva automaticamente pra quando você quiser abrir offline, aliás dá uma pesquisada aqui no fórum que você vai achar umas trocentas vezes essa mesma informação, como aqui:
https://forum.dji.com/forum.php? ... =149972&pid=1379981
https://forum.dji.com/forum.php? ... =151873&pid=1397847
https://forum.dji.com/forum.php? ... =149972&pid=1374914
https://forum.dji.com/forum.php? ... =149534&pid=1369289
https://forum.dji.com/forum.php? ... =145849&pid=1326773
2018-8-18
Dronezoom
P4P+_Brazil Posted at 2018-8-18 04:55
É realmente este preciso testar.
Agora tenho o problema de gimbal vibrando. e isso esta afetando as filmagens! Tem a Floripa drones que arruma isso, porem sou de SP! Eles moxem na firmware do drone tirando a "carga" excessiva do motor do gimbal
2018-8-18
Property Pilots
Flight distance : 653323 ft
New Zealand
My p4p+ does this also. My self unlock refresh does not work, and I have no maps. I have reinstalled the firmware on the controller, and it seems to have fixed my camera aiming left slightly.
But I cannot self unlock, it refreshes but nothing happens.
Also I have no maps. The main home page button does nothing. Whether online or offline.
2020-5-24
