Please help!! AGRAS MG1S BATTERY ERROR
12
2581 57 2018-8-15
MOZZIES
DJI Susan Posted at 2018-10-21 22:36
Hi MOZZIES, we're sorry to read the troubles. Could you upload the screenshot of the battery code and the indicator issue? Please also provide us with the version number, we'd like to check the exact status and see whether it can be figured out remotely.
Good Evening,
I am currently trying to work with tech support.  We have a quite a few issues and notices popping up in the program.  I need to verify the activation code because I can't even get it into the air.  I want to start there.  The first time we got the unit it never had one.  Then it went back to the dealer and was repaired and not sure if it is even a valid number.   I will get back with you if I can't get it fixed.  I am hoping it will help.
Thanks
2018-10-23
DJI Susan
MOZZIES Posted at 2018-10-23 18:22
Good Evening,
That's OK. If there is anything else we can help, do not hesitate to contact us.
2018-10-24
fercho70
Ecuador
Hi amigos, We have the same problem with an Agras MG-1S,  what the problem is ??
2018-11-13
DJI Susan
fercho70 Posted at 11-13 16:20
[view_image]
[view_image]
Hi fercho70, we're so sorry for the troubles. Please kindly contact your dealer and ask them to send an email to agras.support@dji.com, the designated team will take care and help you out.
2018-11-14
Alejandro Giraldo
Colombia
Hi guys in pretty sorry to say but hace the same issue , i bought AGRAS MG 1S june 2018 and in having the same problem with 2/8 batteries. My dealer is scorpion drones .
2018-11-24
DJI Susan
Alejandro Giraldo Posted at 11-24 09:40
Hi Alejandro, we're sorry about the troubles. It is recommended to contact the dealer and report the issue at your earliest convenience, the designated team will take care and help you.
2018-11-26
Alejandro Giraldo
Colombia
Please guys i really need help, i’ve been spraying a lot lately and i need to use these batteries.
2018-11-26
Alejandro Giraldo
Colombia
DJI Susan Posted at 11-26 02:58
I already contact the dealer but he is not giving me any solution. Please please help
2018-11-26
DJI Susan
Alejandro Giraldo Posted at 11-26 07:44
Please kindly ask the dealer to send an email to agras.support@dji.com, the designated team will take care of it. If they cannot help, please kindly provide us with the specific contact information both the dealer and yours, we'll forward to the management to investigate.
2018-11-27
pahpad2
Iran
Hello
good day
I have a battery error
All the battery is in healthy software
Storage battery
But again, it shows a battery error and I'm very sad about this
Give me a solution
2018-12-25
pahpad2
Iran
On the fly, it's a lot of battery error, and sometimes it fails and turns off in fast charging
2018-12-25
pahpad2
Iran
please help
2018-12-25
Hi pahpad2, sorry for the troubles with the battery, may I verify if you have tried other batteries? Does every battery have the same error? What is the exact model of your Agras?
2018-12-25
WDZN8R
Hey DJI,  what is the fix to this MG-1200S Battery problem?  My 4 MG-1200 batteries work fine in my MG-1S but the 3 correct batteries, the MG-1200S ones, all give me the battery communication error?  These batteries are WAY too expensive to be unserviceable after only 20 or so uses.
3-30 17:10
DJI Susan
WDZN8R Posted at 3-30 17:10
We're sorry for the inconvenience. Please kindly contact your dealer to send an email to agras.support@dji.com, the designated team will take care and help you out.
3-30 23:15
aod2
South Korea
I and the people around me are suffering from the same symptoms.
Many machine owners have the same error.
It is questionable why dji does not share a solution.
It just doesn't matter who you bought it from.
What's wrong, what's the solution?
Your company is a large corporation and you have a duty to inform it.
8-15 15:17
Niko43
Hi.. i'm Niko from Indonesia
I have the same problem with my Agras MG1S "Batteray Signal Error" and "failed to authenticate batteray"
10-4 14:42
DJI Susan
Niko43 Posted at 10-4 14:42
Hi Niko, we're sorry for the inconvenience caused. It is recommended to reach the right team agras.support@dji.com for further assistance, thanks!
10-4 22:37
12
