fans6d163aad
Flight distance : 757976 ft
Hi, my Ronin S (its new) is not pointing straight. I already restore all the settings. I also made the Auto Tune and every time I press the auto-center (double click on the trigger), the gimbal goes a little to the left.
In the pictures bellow you can see the correct point that I adjusted with the joystick (IMG_6699.jpg) and the second when I press the trigger button twice to "center" the gimbal (IMG_6700.jpg).
I used the box perfectly aligned with the table and then I aligned the right connector (opposite side of the focus wheel) with the box and than I printed the screen to help to see using the grid.
In the third picture (IMG_6702.jpg), you can see when I press the trigger 3 times, the gimbal goes do the left (my right side).
I'd like to know what I can do to solve this problem.
My firmware is 1.1.0.0 and the app version is 1.1.2 (111)
Regards,
Raphael
