New Tello Firmware Released (v01.04.35.01)
Home / TELLO /
123Next >
29720 89 2018-8-17
fanse98062e3
Slovenia
Thanks for response.
I have FPV issues with all tello firmware versions. I am on v01.04.35.01 right now (update worked with latest android version). I will try clean reinstall and reset tello wifi.
2018-9-5
fanse98062e3
Slovenia
1 more question:
Tello Battery Charger,STARTRC 3 in 1 Multi Rapid Parallel Dedicated Intelligent Battery Charging Hub Batteries Manager for DJI Tello Drone (on amazon)
is that charger ok? Have only 1A output. In quick start guide state  ...use certified USB adapter 5V and 1.5A or above...
Thanks!
2018-9-5
fanse98062e3
Slovenia
Hi!
I have now T1d controller...issue with FPV is when I enter settings and then more(image quality, altitude, bitrate....)..and go back...I lost FPV, BT connection with controller and tello wifi, but tello wifi reconects and I can still control him over phone (no FPV). Only setting I adjust and stays in 'more' is altitude (30m).
regards...
2018-9-7
Hlias Ros
Hello I have the latest firmware in note 8 with oreo android  I have with last firmware problem with photos!! When I want to show the photes the don't open... All screen has Grey color??? Video is Okey I don't have any problem before!!
2018-9-7
Roberto Flavio Titi
Salve ragazzi un mio amico e stato truffato su una vendita di un phantom3 3,se vi invio una foto mandata al mio amico è possibile risalire al prodotto con la garanzia, vi ringrazio in anticipo
2018-9-8
Roytala
Flight distance : 2228 ft
Since v1.04 altitude was upraded, what’s the maximum wind speed can it handle, since wind speed at 30 m is different from ground level.  Thanks
2018-9-8
sebancb
Uruguay
Hello,
I own a Tello and we are having troubles with the programmable block TAKE OFF. Each time we take off the drone it moves like 30cm to the left, it lost the main position. It take of but moving a little to the left and when we area trying to avoid some obstacles it´s  a big issue because it change all the path. This firmware update fix that issue? NOTE: We are programming with Sctratch.
I will be really grateful if you find a solution for this bug.
Best,
2018-9-10
kamilsaim
Turkey
Fotoğraf kalitesi ayarı ve video görüntü aktarım ayarlarınıda her seferinde girip değiştirmek zorunda kalmasak ?
bir sefer ayarlayınca kayıtlı kalsa olmaz mı ?
2018-9-10
cartek
Slovenia
sebancb Posted at 2018-9-10 07:51
Hello,
I use DroneBlocks and works fine. After firmware update I have to create new mission (old missions work wierd).
2018-9-11
JG-N
cartek Posted at 2018-9-11 08:10
Have you seen that DroneBlocks has a new chrome app? You no longer need to use a smartphone.
2018-9-11
cartek
Slovenia
JG-N Posted at 2018-9-11 08:43
Nice...I will try....I also try TELLO EDU....regards
2018-9-12
sebancb
Uruguay
Thanks, I will try with Droneblocks. The thing is that I´m teaching scratch to my students. But I will give it a shot.
Thanks,
Seba
2018-9-13
Brandon Zhun
Malaysia
can you update the tello maximum altitude to 50m?
2018-9-13
Roytala
What’s the max windspeed it can handle if it can go up to 30m?
2018-9-13
RYZE
Super Moderator
China
Roytala Posted at 2018-9-13 13:27
Hey Roytala, it is recommended to fly the aircraft in a place without wind following the content mentioned in Tello Disclaimer below.
2018-9-13
RYZE
Super Moderator
China
Brandon Zhun Posted at 2018-9-13 05:31
Sorry that there is no notice yet. kindly noted that the VPS (vision positioning system)  has an effective range. The Tello will lose VPS with higher altitude which may result in the Tello drifting. Meanwhile, the connection between Tello and the mobile phone might be lost due to the weaker or even no wifi signal at higher altitude.
2018-9-13
RYZE
Super Moderator
China
kamilsaim Posted at 2018-9-10 12:43
Sorry for unable to reply you in time. Sorry that the app configuration would be returned to default setting after rebooting Actually High quality only changes the file size, the quality is the same. To change image quality, you can adjust the bit rate in APP to 4M. Hope the info would assist and sorry for the inconvenience caused.
2018-9-13
mike w.
Worked fine when I received it in the mail. Incredibly easy to set-up and fly.
This morning I got a message that my "firmware" eede t be updated. Downloaded it and when paired to the drone (they should tell you to have this powered on and paired already), it only got to 30%.
Never advanced from there and not the Tello won't fly. From the previous posts on this thread it seems some kinks have not been worked out yet.
How to proceed?
Thanks,
mike w.
2018-9-19
RYZE
Super Moderator
Sorry for your unpleasant experience Mike, in regard to your case, please Hold the power button with power off for about 5s until the green led goes off, wait for a moment until a slow red flashing led lights up. Then please connect Tello 's wifi and redo upgrade.  Hope it would help. Have a good day~
2018-9-19
SAYG
Flight distance : 364403 ft
Someting happened with firmware update. Updated would not finish. and noe my tellow will noe turn on nor ill the batterys take a charge. What's up with that?
2018-9-21
RYZE
Super Moderator
China
SAYG Posted at 2018-9-21 07:15
Upgrade failure may lead to this issue. To correct it, please hold the power button with power off until the green led goes off, wait for a while,  it would light up red which is flash very slowly. Then please connect Tello's wifi and redo upgrade.
2018-9-23
stevenry
Philippines
uhmm can i ask a question?...Every time i set the BIT RATE to my tello to 4mb it decrease to 3mb after i go back to settings to double check the setting... why is that?...also my tello turning off when warning says over heat i didn't even fly my tello?..why is that?...please help...!!!!
2018-9-30
RYZE
Super Moderator
China
Thanks for bringing this our attention Stevenry. We haven't met this issue yet, but we care much about your feedback. Would you be so kind to record a video showing this problem, plus screenshots of firmware version, APP version as well as model number & system version of the mobile phone, which would be delivered to engineer for further analysis? Meanwhile, you can also send them to support@ryzerobotics.com. We are very happy to help.
2018-10-1
Felix Ong
Malaysia
Hi, I tried to update the firmware however when the update reached 99%, it stuck there and never complete. I waited for like more than 10 minutes and the Tello heat up.  Should I follow what they said earlier by reinstalling the older app and perform the update? My Tello(Global) was manufactured on 2018/6
2018-10-8
Felix Ong
Malaysia
Felix Ong Posted at 2018-10-8 09:34
Also, when i connect to my drone, the live view did not shown properly.
Is it because of the app itself or firmware.
I just got the drone today and have quite bad experience on it...
2018-10-8
RYZE
Super Moderator
China
Felix Ong Posted at 2018-10-8 10:44
Sorry for your unpleasant experience Felix. In regard to your case, first please install the latest  APP version.  Then please kindly conduct the troubleshooting below:
Hold the power button with power off for about 5-8s until the green led goes off, wait a while, the flashing red light would continue. Then please connect Tello's wifi and redo upgrade.
Hope it would help and if you are still encountering this issue, please do feel free to respond or contact us at support@ryzerobotics.com or get the online support at https://www.ryzerobotics.com/support.
2018-10-10
djiuser_OoleGKJqKNoa
Brazil
Pessoal meu dji tello deu problema no motor dai fiz a troca direitinho e quando dou o comando ele aciona os motores porém não decola alguém pode me ajudar??
2018-10-17
RYZE
Super Moderator
China
Welcome to the forum, OoleGKJqKNoa. In regard to your concern, first please check if propellers are installed properly according to the image below. If not, please correct it.  If persists, it might need repair service. Please contact the right support at support.cn@ryzerobotics.com for further assistance.
2018-10-20
Marcos Santos
Brazil
Friends I'm using Motorola Android One, with Android 8.1.0, the camera is in error, is showing colored stripes, there is no image, does anyone know how to fix this problem?
Tks!
2018-11-10
RYZE
Super Moderator
Marcos Santos Posted at 11-10 05:38
Tks!
Hey Marcos,sincerely sorry that Motorola Android device is not in the recommended device list. How about trying other camera APP.   If persists, you can try the devices in the recommended list https://www.ryzerobotics.com/tello/downloads
2018-11-16
BrkTnl
Turkey
Hi. I have a issue about the app. I updated tello when this upgrade released on August. The problem is that when I open the app, it warns there is a update for tello. But I connect the drone to my device, the app says your firmware is up-to-date. Which one is having a problem? Thanks.
2018-12-6
RYZE
Super Moderator
China
BrkTnl Posted at 12-6 00:55
Thanks for bringing this to our attention Brktnl. We haven't met this issue at the time being. Could you please record a video showing this issue, plus the screenshots of APP version & firmware version, of the system version of your phone for further analysis? Thank you in advance.
2018-12-6
BrkTnl
Turkey
RYZE Posted at 12-6 04:15
Sure, here they are.
2018-12-6
Louzada
Brazil
After updating firmware Tello has not been able to take off again. There is a start up, lot of torque and tries to lift up, flipping over right after. I already tried to restart and reinstall app and firmware. I bought it 2 days ago and already regret it.
2018-12-8
Louzada
Brazil
Louzada Posted at 12-8 17:21
Ok, replying to myself. I have solved the issue.  The marked props were not set up properly.
2018-12-9
Joe Schmo Force
Flight distance : 448671 ft
My recorded video looks much better after the update on my Samsung Galaxy 7.
Thanks for the update!
2018-12-14
RYZE
Super Moderator
China
Joe Schmo Force Posted at 12-14 18:46
Appreciate your update and positive feedback Joe, we are pleased to hear everything turns out to be great, enjoy it and happy droning!
2018-12-16
Erry Sudew
Malaysia
Ive already try 3 times to update the firmware and the result are same.,it stuck at 99%.Btw, im using Oppo A83.. Is it because of the phone?.. Hmm
2018-12-20
RYZE
Super Moderator
Erry Sudew Posted at 12-20 02:45
Hey Erry,welcome to the forum. In regard to your concern, you can try the method below 1. Please power off the drone, then hold the power button for about 5 -8s until the green led goes off [ Gotta release the power button once the green led goes off].
2. Then a flashing red led should go on automatically.
3. Connect Tello's Wifi
4. Launch into Tello APP, go to Setting - More setting - click " three points " - upgrade firmware version.
2018-12-21
tejas hadkar
India
wow.. with thr new update tello image stabilization is as good as spark.. just wow
earlier it was like mitu.. lol.
i think ppl who are crying try firmware update and calibrate imu without props twice n restart drone.
then always open app then start wifi through app n connect tello
just  request to ryse to add battery percentage even though its a little bit inaccurate it will help..
also possible manufacture a controller with phone holder and inbuild wifi booster like spark has..
2018-12-23
123Next >
