djiuser_8T8oCqHPf0GZ Posted at 2018-9-6 09:57
Hello, I've tested spark indoor with prop. guards. Before flying checked imu&compass calibration they were good but recalibrated them once again. After i started to flyi noticed that Spark is not stable like before even its a small move he is moving little by little is that a problem or?
This is normal, usually, there is no enough GPS signal when flying indoor, the drone will revert to A-mode when the GPS signal is weak, in this mode, the drone cannot position or auto-brake itself and easily affected by its surroundings, therefore, we recommend to fly in an open area with the strong GPS signal, please test outdoors, thank you. |
