Pixallated and huge lag on my phone from mavic
774 9 2018-8-17
fans553ef7bf
Flight distance : 318927 ft
Any help much appreciated .
Ive tried everything , firmware roll back new cables,deleted my cache . Turned off all data wifi and Bluetooth on my phone,
New memory card. Rapidly getting fed up with the mavic. Had to buy a new batery a week or so ago as i got the dreaded unbalanced baterry, only had 16 charges on it. Emailed dji europe and would you believe it. No reply . It was only 13 months old . That works out at 5 quid a flight .
2018-8-17
msinger
Flight distance : 228255 ft
If you haven't already done so, try the additional tips from this article. They'll help you ensure both your mobile device and DJI GO are set up to run as efficiently as possible.
2018-8-17
Bekaru MP UAV
Flight distance : 15513100 ft
South Africa
what device/phone are you using?
2018-8-17
fans553ef7bf
Sony experia zx
2018-8-17
DJI Gamora
Hi, thanks for reaching DJI Forum. We do apologize for the troubles you are having with your device. May we ask for the mobile device you used where the app is downloaded? I will be posting some of the listed fully compatible phones to run the app. Thank you.
2018-8-17
Paul_IA
Flight distance : 4959019 ft
I sympathize with you regarding the the fact that Go 4 requires a beefy device to work properly. I had similar issues with an "unsupported" device and finally bought a CrystalSky.
2018-8-17
fans553ef7bf
Paul_IA Posted at 2018-8-17 06:53
Thanks for for the advice but my phone was working perfectly until the update dji released in March.  Maybe another case of dji lack of testing before firmware releases
2018-8-17
Paul_IA
fans553ef7bf Posted at 2018-8-17 07:37
I hear you. But in reality, DJI isn't going to change their software for what they call "unsupported" devices even if that device has worked with their drones for a year (that was my situation).
So we either dump more money into our hobby and get equipment that's on their list or we deal with the frustration you're describing here.
2018-8-17
DJI Natalia
Hi, I'm sorry to hear about that. Actually, there is a possibility that it will work, however, since it's not yet optimized with our application we cannot guaranteed the stability of the application if this will work all the time while using the specific mobile device. We highly suggest you use the compatible device that was listed on our website to avoid any problem. Thank you.
2018-8-17
fans553ef7bf
I have a Sony tablet that is running at optimum per for I'll try that add see if it flys OK. I if it does I'll use that and look at a compatible
2018-8-18
