DH_Pilot
Flight distance : 3301621 ft
Slovakia
Please try this to disable driver signature enforcement on Win10:
Select the “Start” button.
Type “startup”.
Select “Change advanced startup settings“.
Select “Restart now” under the “Advanced startup” area.
Select “Troubleshoot“.
Select “Advanced Options“.
Select “Startup Options“.
Select “Restart“.
A menu will appear where you can press “7” on your keyboard to choose “Disable driver signing enforcement“.
Once you will have Windows running with disabled driver signature enforcement check the Vision 3 interface in device manager if it will still have the icon with the black arrow icon down, right click on it and click "Enable Device" it should be enabled and operational and you should be then able calibrate vision sensors. |
