DJI Gamora
Hi, thanks for reaching DJI Forum. We do apologize for the troubles you had.I f an Intelligent Battery has been stored for an extended period, but it has not been charged and discharged, its protection board cannot balance the battery’s cells sufficiently to avoid a significant voltage difference. When the voltage difference exceeds the safe threshold, the battery’s cells will become damaged.
To avoid this, we recommend that you discharge the battery to 40% to 65% of its total power and store it in a cool, dry space (at an ambient temperature of 22°C to 28°C) when it is going to be idle for more than 10 days. Check the battery’s power every three months and fully charge and discharge it at least once. Please perform routine maintenance to keep your battery healthy. Hope this helps. Thank you |
