Ronin S loosing power?
606 8 2018-8-19
Agustinmgc
Mexico
I was trying to get an infinity shot with a 6D mkii mounted (total payload 4.11 lbs). It started strugling with the camera turning and then it smashed it! I balanced it correctly, auto tuned the motors and calibrated the gimbal before using... please help!
You can see it in the video..
2018-8-19
Agustinmgc
Mexico
Now I'm Getting these problems!
2018-8-19
Agustinmgc
Mexico
2018-8-19
Nohchilife
Tried with another lens?
Are you running the latest firmware?
Have you done a joystick calibration?
2018-8-19
Agustinmgc
Mexico
that lens is the one I need to shoot with.
I actually downgraded the firmware and it got a little better, still shakes but not as intensely
how do I perform a joystick calibration?
2018-8-19
Nohchilife
Agustinmgc Posted at 2018-8-19 18:18
Tap the trigger 4 times, and hold on the 4th tap. All 3 mode lights should blink, then move the joystick multiple times all over the place.
Tap 4 times and hold on the 4th tap to finish calibration.
2018-8-19
Agustinmgc
Mexico
thanks for your help!
2018-8-19
Nohchilife
You're welcome, I hope this can help.
2018-8-19
Hi Agustinmgc, sorry for the difficulties on running Ronin-S, may I know if the issue persists after the joystick calibration? Did you try the system calibration?
2018-8-19
