DJI Tony
fans84dd369b Posted at 2018-8-20 15:24
I don't know how to connect via wi-fi. I plan to go to a remote field tomorrow and hopefully talk to an owner of a Mavic Pro and get his help. Do you know what a flashing green light means at the stern of the aircraft while the IMU is being calibrated? How long do I have to wait for the first step to be completed? A short while, ten minutes? The video really doesn't say --- it could be edited to shorten the the view time; when it really takes a lot of time to calibrate. How level must the flat surface be?
Hi, Thanks for the response, normally, it wouldn't take to long during the IMU calibration as long as we follow the instruction on the screen. Probably the reason for the green light while calibrating is that the aircraft proceeding the IMU calibration. Regarding the phone and aircraft connection, you can switch the aircraft from RC into Wi-Fi then locate the Wi-Fi name on your mobile device if you're not aware of the password, that details will be included on the battery compartment as well. Please see the images below for your reference. Thank you for the support. Kindly keep us posted on the latest progress.
