Mavic Pro wont take off, only tilts forward and stops
2155 15 2018-8-19
JadedKingJ
Flight distance : 215128 ft
I really hope you guys can help me with this. I have had a Mavic Pro for about 4 monthes and yesturday took it out to fly and when I used the take off button or the manual engine start with the joysticks... the MPs blades sound like its going to take off but then it tilts forward and engines stop. I proceeded to do a IMU and Compass calibration and also a remote control Calibration, but still does the same thing. Im usuing DJI standard blades and have never had a issue with it since new. Any suggestions would be GREATLY appriciated!! Thank you in advance for any help you can give me!!
2018-8-19
The Farmer
Flight distance : 165495 ft
Check the props for damage and make sure they are in the correct arrangement and securely locked. I had that happen once when a prop was not installed correctly.
Post a flight file to find out for sure.
2018-8-19
Lucas775
Flight distance : 50642090 ft
Make sure your props are on their right position(not my video)
2018-8-19
Paul_IA
Flight distance : 4959019 ft
As above, assuming you have the right props on the right motors. If so and you still have the same problem, post your flight log and it should tell you why it's refusing to take off.
2018-8-20
JadedKingJ
Paul_IA Posted at 2018-8-20 03:23
How do I go about uploading the DAT file to this site?
2018-8-20
JadedKingJ
Heres a link to the DAT file
https://www.dropbox.com/s/nbzo8e ... -53_FLY098.DAT?dl=0
2018-8-20
Bekaru MP UAV
Flight distance : 15513100 ft
South Africa
go to your RC settings in main menu and enusre you are in RC mode 2. Perhaps this setting changed somehow and might be causing your issue.
2018-8-20
Paul_IA
Upload your log file in the DJI Flight Log Viewer and post the link to the results back here.
2018-8-20
JadedKingJ
Heres a link to the txt file on my dropbox..
https://www.dropbox.com/s/8zwa2y ... 9-46-09%5D.txt?dl=0
2018-8-20
JadedKingJ
http://www.phantomhelp.com/LogViewer/BU488NCT66XX7DWKS2LC/
2018-8-20
JadedKingJ
http://www.phantomhelp.com/LogViewer/7FY65XKAFJP8RU7PONFA/
2018-8-20
JadedKingJ
http://www.phantomhelp.com/LogViewer/2OCCZHLXXZ61Y65OJWTG/
2018-8-20
Koelkop
Flight distance : 22814806 ft
South Africa
Try posting a video of it. Someone else on here had something similar and it turned out his ESC's were faulty causing the back props to spin up and not the front ones
2018-8-20
JadedKingJ
WELL LADIES AND GENTS... THE MAVIC HAS PROVED IM A IDIOT AGAIN... AFTER ROLLING MY EYES READING ALL THE COMMENTS ABOUT MAKING SURE THE PROPS WERE IN THE RIGHT SPOTS... I FINALLY TOOK A LOOK AT A PICTURE OF SOMEONES MAVIC AND NOTICED MY WHITE CIRCLE PROP WASNT ON THE CORRECT SIDE... I GUESS WHEN I CLEANED THEM THE OTHER DAY I PUT THEM ON WRONG. SO ONCE AGAIN.... YOU GUYS ARE THE BEST!!
2018-8-20
JadedKingJ
........ SO I CHANGED THE TOP PIECE OF THE MOTOR AND PUT THE PROPS WHERE THEY SHOULD BE, AND SINCE ITS RAINING... FLEW IT IN THE HOUSE FOR A FEW MINS... WORKED LIKE A CHARM
2018-8-20
DJI Natalia
JadedKingJ Posted at 2018-8-20 10:35
Hi, Awesome! That's good to know that it's now working. Just remember to check your props everytime you fly to avoid any problem. Should you have any further concerns don't hesitate to reach us. We're here to help. Thank you and have a safe flight always.
2018-8-20
