Kurtisbadical
“Dear Kurt, Thank you for contacting DJI Technical Support. We are grateful to assist you with your concern. Regarding this issue, please try below operations. 1. Calibrate the Control Joystick and Roll Knob. Ensure the gimbal is powered off during calibration. 1). Press the C1 + C2 buttons once, then press them simultaneously and hold them until the long beeping changes to a continuously short beeping "DDD, DDD, …" sounds, which indicates the calibration has begun. Don't touch the joystick until calibration starts. Repeat step 1 if calibration fails to initiate. 2). Push the joystick to the endpoints in multiple directions (top, bottom, left, and right) multiple times and rotate the roll axis knob clockwise and counterclockwise to the end point, respectively. 3). Press and hold the C1 and C2 buttons at the same time again to exit the calibration. The remote controller will emit “DD” sounds if the calibration is successful. If no sound is heard, the calibration fails. If so, repeat the steps above. 2. Do system calibration Looking forward to hearing from you soon. Thanks for choosing DJI. Have a nice day!” |
