aaapoc
aaapoc Posted at 7-5 06:10
Hi all. I'm facing a similar issue to thestorybehind's, except it's panning non-stop 360 degrees. I have a feeling it's something to do with Control Settings' Channels section. The sliders from CH1-3 are locked and cannot be modified. CH1-2 are set to 0, but CH3 (for Pan) is locked to a value between 245-250, which I suspect is causing it to pan on its own non-stop. The joystick works, but it will continue to pan after I left go the joystick. Restore Gimbal Settings and System Calibration do nothing. I'm running the latest app and firmware versions.
Any advice would be much appreciated.
Update: got it working again, thanks to support's help. Joystick recalibration resolved it. Here was their instructions:
Press the trigger button 4 times and hold it on the 4th, the 3 LED lights will be solid green then eventually blinks, once it started to blink push and pull the joystick up down left right and circle around multiple times until the LED light turns normal. You may redo the process twice. |
