eried
Flight distance : 661362 ft
Denmark
DJKOR Posted at 2018-8-28 00:22
Just don't try that one again. There is a good chance there is protection circuity (or simple diode protection) built into the DJI Battery to USB adapter but I wouldn't rely on it.
As for the powerbank with the integrated inverter, which a solution to the issue of not being able to charge on the go, it unfortunately does not eliminate the need to have the mains charger with you as well. Depending on what you are after, this may or may not suit your needs.
As a companion for my powerbank I have a small solar panel that takes like 5 hours to recharge the powerbank again, so it is a complete loop.
Not suitable for some cases, like going for an afternoon,, but ok for camping and trekking |
