tilting issue or guidance needed
405 5 2018-8-20
Mitalpatel
Flight distance : 104560 ft
India
hi i am new to ronin s or gimbals
for the first i saw few videos people shows tilting thr grip keeps camera front facing.
mine is tilting camera along the grip down or up.
is this normal?
calibration and balance shows excellent result ..
kindly guide
2018-8-20
StianGel
Flight distance : 686654 ft
Norway
You need to hold the trigger button to have the camera pointing in the same direction regardless of the handle movement.
2018-8-20
Surface2Air
Flight distance : 167441 ft
[Edit: Apparently I misunderstood the question.] I think what your looking for (someone correct me if I'm wrong) - when the unit is off and well balanced, and your able to tilt the camera left 45, right 45, up, down etc. without the camera moving on its own.. whether your holding the grip upright or tilted forward - your good to go.
2018-8-20
Hi Mitalpatel, please try to close the Smooth Track to see if this is what you expect, thank you.
2018-8-21
Mitalpatel
India
thank you.. shall check back and post.
2018-8-22
Mitalpatel
India
hello all. after setting up smooth option disable it worked.
2018-9-8
