Cetacean
Flight distance : 2494390 ft
Aloha Brice,
When you calibrate the Remote Controller, be sure to move the wheel slowly and check to see if all the numbers from 1-100% are clearly shown. Remember, it takes 5-10 seconds for the numbers to start to respond to the movement of the wheel and even the sticks. Once you have started and all the numbers are displaying properly, and even with the sticks you can get a 45 degree read-out with two 100%, then press done and see how it works.
It takes a long time for the computer to start the initial calculations but after that it goes quite quickly. The older P3 series Phantoms like my P3 Pro are particularly slow to start the calculations.
Hope this helps!
Aloha and Drone On! |
