Hey its my first thread here. i am a newbie in drones world.i have bought mavic pro a couple of days back. neeed to calibrate its vision sensors. I have installed DJI assistant 2 v1.2.4 from DJi website but this software won't recognize my aircraft. i have reinstalled the software again but the problem remains same. Kindly someone guide me.
Hi there, thank you for reaching out. About your question, I would suggest giving a try to disable first the firewall or anti-virus in your PC before Installing it just to make sure the drivers will install properly and after that restart your PC.
DJI Stephen Posted at 2018-8-22 11:45
I tried these steps on my laptop again.. deleted the assistant app. Cleared the cache and temporary files of C drive.. Downloaded the assistant app again from the dji website. disabled the driver signature enforcement,. Installed the app and it worked..
Jamal1 Posted at 2018-8-23 03:45
Thank you Again everyone
Hi, we're glad that you finally downloaded the app on your PC. Should you have any concerns don't hesitate to reach us. We're here to help you always. Thank you.
djiuser_89Wfmgy2SUyp Posted at 8-20 06:10
I spent a couple frustrating hours fighting this. Finally switched to a different USB charging cable and it worked perfectly.
Well, not all usb cables are created equal..
Some have better data transmission abilities, like, the cable that came with your device.
Not the overpriced cables you can buy of the cheesy rack in the gas station/7-11...
Has this been resolved? I am still having this problem that the DJI Assistant 2 (for Mavic Pro) will not recognize the aircraft. Have tried on 3 macs and 1 PC with 3 different cables. Have also tried re-installing, restarting, etc.
Andrewk108 Posted at 2020-1-6 12:27
Hi did you get to work? i have the same problem as you.
Yaros1 Posted at 12-24 13:40
If you use Mavic Pro 1 you will need the old version of DJI assistant. Can be found here:
https://www.dji.com/downloads/softwares/assistant-dji-2
Yaros1 Posted at 12-24 14:44
Yes, this is DJI Assistant for older drones, such as Mavic Pro 1. You can see it in the supported products in your screenshot as well.
Thank you so mutch for you help i will try this one :-)
