Mavic 2 with Ocusync 2.0 Update, non issue.
6003 35 2018-8-23
Jeff Millard
Flight distance : 503635 ft
Edit: I learned that my belief that Ocusync 2.0 wasn’t compatible with the first version, was incorrect. So please disregard my post. According to DJI the Goggles will be compatible with Mavic 2.0.
Jeff
2018-8-23
Far_North
Flight distance : 278379 ft
You said, "All this hype, and nothing".  You must be blind and deaf........bye.
2018-8-23
FlyDK
Flight distance : 1636286 ft
Denmark
Come on man..!
Fly it without the freaking goggles witch isn't quite safe to use anyway.
2018-8-23
Buzzyone
Flight distance : 4647913 ft
It is compatible with Goggles, but only in the 2.4Ghz range, RE supports 2.4 & 5Ghz
2018-8-23
Mir
Flight distance : 2718491 ft
Maybe some clarification is needed. I have the white "regular" goggles that first came out. Are they compatible with the Mavic 2?
2018-8-23
engelo
Flight distance : 12311667 ft
Greece
I also have the "white" googles !!! Can i use them with Mavic 2?!?!?!?!?1
2018-8-23
eYeSkYeYe
Croatia
Will Goggles RE show 720p or full 1080p streamed video when used with Occusync 2.0?
2018-8-23
Woe
Flight distance : 4129268 ft
eYeSkYeYe Posted at 2018-8-23 08:20
Look like it said full 1080p. Awesome
2018-8-23
DJI Thor
Flight distance : 13602 ft
Hi Jeff, just to clarify, the Mavic 2 supports DJI Goggles version 01.04.0500 (or later versions) and DJI Goggles RE version 01.00.0600 (or later versions), you may refer to the screenshot below.
Besides, I noticed that you mentioned the issue about the Mavic controller, may I know the issue that you had encountered? I would like to help. ggles.png
2018-8-24
DJI Thor
Mir Posted at 2018-8-23 08:15
Hi Mir, yes, they can be compatible with the Mavic 2 series after the firmware update to v01.04.0500 or later, you may refer to my answer above, thank you.
2018-8-24
DJI Thor
engelo Posted at 2018-8-23 08:18
Hi Engelo, please kindly refer to my answer above, thank you so much.
2018-8-24
DJI Thor
Hi there, yes, both DJI Goggles and Goggles RE support 720p@30fps (at this moment) / 1080p@30fps, thanks for your attention.
2018-8-24
ghostrdr
Flight distance : 1272723 ft
I hear there are some really good deals available on the Karma!
2018-8-24
davidmartingraf
Flight distance : 106566408 ft
Honestly, I don't know how DJI could not incorporate compatibility with OcuSync 2.0 and the DJI Original Goggles? The Racing Goggles are made primarily for racing drones, then if that's the case then we should be entitled to see a drop in price for the racing addition to the same price as the current original Goggles?
2018-8-24
bjr981s
Flight distance : 139698 ft
davidmartingraf Posted at 2018-8-24 06:19
Is english a second language to you? I think google translate made a mess of your comment as it does not make any sense.
Could you phrase your comment differently? And do the translate again?
2018-8-24
engelo
Greece
DJI Thor Posted at 2018-8-24 00:46
Thank YOU !!!!!
2018-8-24
davidmartingraf
bjr981s Posted at 2018-8-24 08:12
I am commenting about why DJI Goggles original edition can not be compatible with Mavic 2.
2018-8-24
DedeMavic
Flight distance : 649403 ft
Switzerland
davidmartingraf Posted at 2018-8-24 14:33
Mavic 2 supports DJI Goggles and DJI Goggles RE!
2018-8-24
hallmark007
Flight distance : 9827923 ft
M2P/zoom support all dji goggles.
2018-8-24
davidmartingraf
DedeMavic Posted at 2018-8-24 14:56
Good to know - thanks!
2018-8-24
davidmartingraf
hallmark007 Posted at 2018-8-24 15:02
I get it - I wonder why there is confusion about many thinking only the RE are compatible?
2018-8-24
bjr981s
davidmartingraf Posted at 2018-8-24 19:34
The RE has additional functionality being able to auto-switch between 2.4 and 5.8Ghz.
A function of Occusync 2.0.
Occusync 2.0 is forward and backward compatible at 2.4Ghz for Occusync 1.0
So RE Goggles work with both Mavic 1 and 2.
Mavic 1 and 2 work with original Goggles.
But. RE Goggles flight packs only work with RE Goggles I believe. Haven't tested yet.
Cheers
2018-8-25
davidmartingraf
bjr981s Posted at 2018-8-25 00:48
I thought there was no difference between the RE and original DJI Goggles, except if you wanted to FPV race drones or anything Analog 5.8 GHz, then the RE Edition was expected to replace the need for someone flying both, DJI and Race Quads, in needing to require two separate pairs of FPV goggles?
As in my case, I fly DJI and FPV race quads and RC planes. I purchased FatShark Dominator V3's and now I'm interested in an FPV experience using the DJI Goggles. I purchased the FatShark's thinking the DJI Goggles weren't as comfortable and that I could just buy both pairs for approx. the same price as the RE Edition. This purchasing theory with the release of the Mavic 2 is now debunked?
What is the difference between Analog video and OcuSync? Isn't Analog video not digital but just a live video broadcast at a much lower latency and resolution than high definition presumably from OcuSync? The OcuSync 1 in the Goggles is not switching betwen 2.4GHz and 5.8GHz because it doesn't have 5.8Ghz band built inside? However, Lightbridge technology does switch between 2.4GHz and 5.8GHz that uses an enhanced WiFi signal to broadcast? But OcuSync utilizes its own frequencies, where there wasn't as much residual usage nor common interference? Although if the Analog is cast over 5.8GHz, how does OcuSync 2.0 now utilize this Analog frequency - to broadcast FHD? Does OcuSync 2 have 5.8GHz built inside and it can switch between OcuSync 1's digital only frequencies with Analog 5.8GHz to still throw out a FHD picture?
What am I missing?
2018-8-25
Lucas775
Flight distance : 50642090 ft
Read before talking!
2018-8-25
davidmartingraf
Dirty Bird Posted at 2018-8-25 12:36
Occusync transmits digital video.  The original goggles will work with the Mavic 2 once you upgrade the goggles to FW 1.04.0500 or above.  The original Goggles, however,  only support 2.4 Ghz so they can only connect to the Mavic 2 on that band.  The RE Goggles support both 2.4 & 5.8 Ghz.
I assume the Mavic 2 will recognize this & limit the connection to the 2.4 Ghz band when it detects a connection with the original Goggles.  Basically you should be good once the new goggle firmware is released.
Thanks. I know OcuSync 2 uses both 2.4 & 5.8 GHz, but does the Mavic Pro 1 with OcuSync 1 support both 2.4 & 5.8 GHz, also or just 2.4 GHz?
2018-8-25
DJI Thor
Hi David, both DJI Goggles and DJI Goggles RE will support Mavic 2 series. Please kindly refer to my answer on 9#.
In fact, DJI Goggles RE had just released the firmware to support Mavic 2. DJI Goggles has not released the firmware, but it will be able to connect when v01.04.0500 released. Thank you for your attention.
2018-8-26
DJI Thor
No problems, Engelo. But the supported firmware v01.04.0500 for DJI Goggles has not been released, please stay tuned.
2018-8-26
bjr981s
davidmartingraf Posted at 2018-8-25 17:30
The Fatsharks are 5.8Ghz analogue. It is an analogue signal not digital.
The Goggles (White) Only Support 2.4Ghz Digital Occusync 1 and is backward compatible to Occusync 2 on 2.4 Ghz only.
The Goggles RE (Black) Support 2.4 Ghz Digital, 5.8Ghz Digital Occusync 2.0 and 1.0 compatible as well as 5.8Ghz Analogue  using the pagoda antenna provided with the RE for Analogue reception. ( same as fatsharks)
Cheers
2018-8-26
davidmartingraf
DJI Thor Posted at 2018-8-26 03:18
Thanks DJI Thor for the confirmation. I think there's been some confusion on my part since the release of Mavic 2. Being a Mavic Pro owner, I was aware the difference between Lightbridge to OcuSync, is that Lightbridge utilizes switching between 2.4 and 5.8 GHz, where OcuSync doesn't. Now I don't understand the difference between OcuSync 2 and Lightbridge? I always thought OcuSync found on the Mavic Pro was the superior transmission to Lightbridge? Now it seems OcuSync 2 is more comparable to Lightbridge?
Any clarification would be greatly appreciated. Thanks!
2018-8-26
davidmartingraf
bjr981s Posted at 2018-8-26 08:50
I am super confused from understanding the difference between how OcuSync can transmit digital over the 5.8GHz frequency? I guess the major difference you're saying is there's a level of latency over OcuSync that prevents it from being adopted over Analog frequencies, which are still being used by drone racers? What is proprietary over OcuSync being a competitive technology, if it has too much latency where competitive drone racers still are required to adopt Analog signals?
Below is a video of someone interviewed from Spektrum RC who states the essence to my paradox. Thoughts, feedback, opinions?..
2018-8-26
DaMa
Flight distance : 889662 ft
Dirty Bird Posted at 2018-8-25 18:05
The Mavic Pro with Occusync 1.x only supports 2.4 Ghz.
From the manual:
2018-8-26
DaMa
Dirty Bird Posted at 2018-8-26 22:38
Is that from the original Mavic Pro manual?
Why would the aircraft operate @ 5.x Ghz when the controller only supports 2.4 Ghz? Sounds like a misprint. To my knowledge the original Mavic only communicates at 2.4 Ghz.  One of the major improvements in OccuSync 2.0 is that it adds 5.x Ghz  support.
In fact, that's confusing. From the DJI side: https://www.dji.com/mavic/info#specs
I am wondering about this:
2018-8-26
DaMa
It looks like Mavic 2 has no pad/phone wifi function - just OcuSync 2.
That should mean that Sync 2 is backwards compatible or the RCs and Goggles get a firmware with Sync 2 support.
2018-8-27
DaMa
Dirty Bird Posted at 2018-8-27 00:13
Hmmm...  The Mavic Pro supports Wi-Fi control from a phone or tablet.  I've never used it but I wonder if it supports both 2.4 & 5.x ghz Wi-Fi connections?  That would explain why the bird shows 5 ghz but the controller does not.
Also never used, but will try it...
Done. I thought it's like similar to Spark - no, it's not, RC is not needed.
2018-8-27
bjr981s
davidmartingraf Posted at 2018-8-26 20:38
Yes you are confused. Think of Analogue and Digital the same way you would think about AM and FM radio.
You cant receive FM on an AM radio and vice versa.
Its the same with old Analogue TV and new digital TV.
Analogue is sending  a wave. Like a Sine wave. Digital is breaking the wave down into its values and converting it to digital packets.
Also Occusync is not WiFi. It is a completely different technology. It just uses the same frequency bands as WiFi.
Hope this helps
2018-8-27
davidmartingraf
bjr981s Posted at 2018-8-27 06:01
I do appreciate your comment, thank you.
This description is informative and explanatory and it paints a pretty good stroke of how to think of the similarities and differences with your analogy.
Others will benefit from reading your post and I gave it an Upvote for its strong content.
2018-8-27
