Push mode? What is it?
4660 3 2018-8-23
WakingLife
What is push mode?
Does this mean I can move the gimbal position with my actual hands? Physically push it (not by the app or joy stick)?
Will this hurt the motors?
Furthermore, for cameras not compatible with the Ronin S record and focus pull like the D750 - will it hurt the Ronin S to manually focus, touch the camera while the gimbal is on?
2018-8-23
Hi WakingLife, you are right, Push Mode means we can adjust the pan, tilt and roll axes by hand when the Ronin-S is turned on, it will not hurt the motors when it is enabled. It should be fine to touch the camera in Push mode.
2018-8-25
WakingLife
DJI Mindy Posted at 2018-8-25 02:13
Thank you for your reply!
If the gimbal is not in push mode. Is okay to manually focus on a camera that can not be controlled with the gimbal?
For example, the d750 must be focused manually. When doing so, you put some weight on the camera/ gimbal. Is this okay?
Can you please also attend to me questions here: https://forum.dji.com/thread-162543-1-1.html
2018-8-27
WakingLife Posted at 2018-8-27 21:26
Hi WakingLife, it is recommended to turn off the Push Mode when you use the zoom lens or manually focus to ensure the gimbal keeps stable, don't worry about that.
2018-8-28
