PatrickM923
Well, I wonder if this might help...(however, I am an avid Apple user, so perhaps there isn't much chance my thoughts will be of much help at all).
Without further digressions, I see in your log files that you were at about roughly 70% of the published range of the Mavic Air (MA), and everything seemed to be going well at that point, and continued to go well until you got to the trees. I wonder if you were then at the end of the range for the MA, and that perhaps the trees caused a change in terrain at that range, which in turn caused some difficulty for the RC. What do you think? Perhaps if you had skirted around the trees, and more in the direction of that McDonald's to the west, those problems would not have occured when they did, though with a published range of ~ 2.5 miles I think you were skirting the edges of the MA capabilities and some sort of loss of signal problem was likely to present itself soon.
Also, I noticed that you are at one of the edges, or boundaries, of the gas station parking lot. From that vantage point, It is difficult, at the end of the video, to see if you have good "line of sight" with the MA. If your line of sight was impeded by foliage or other objects, then perhaps the signal with the MA was even more obscured and impeded between the RC and the MA. Just Sayin'.
Another also....how were the Remote Controller's Antennae oriented?
By the way....very nice video....I liked it and watched it twice. :-)
California USA
