Mavic 2 Pro Battery Connectors Same?
4731 5 2018-8-24
Chasing Light & Shadows
Flight distance : 221476 ft
I understand it's a different battery but are the connectors the same as the Mavic Pro battery? Wondering if my dronemax m10 will charge the new ones??
Thanks,
D.
2018-8-24
DJI Paladin
Flight distance : 318 ft
Hi there, thank you for reaching DJI forum. You are recommended to use the original charger from DJI. It is not recommended to use the third-party accessories, we are unable to ensure the compatibility and the performance. For the battery terminal, you can compare it on the attachment below. Let me know if you have further questions. Thanks for your support.
Mavic 2 pro battery connector:
Mavic pro battery connector:
2018-8-24
Thanks for the reply and taking the time to post the pics. Unfortunately I can't confirm 100% with the pictures as the internal wiring could be different.  But saying that, it does have the same amount of pin sockets so it looks promising at least.
2018-8-24
cristiano1976pt
Flight distance : 322156 ft
Would be nice to know. Because I own the DJI MAVIC PRO CHARGING HUB V2 with the Phantom 4 Serie 160 W Power Supply. And I won't give up this combination because of the CrystalSky AC Plug. So would be nice to know if the other things work.
2018-8-24
cristiano1976pt Posted at 2018-8-24 07:10
I still don't know for sure but from what I can gather so far they're not going to be compatible but will be more than happy if I'm wrong!
2018-8-25
GekoCH
Switzerland
Chasing Light & Shadows Posted at 2018-8-25 02:49
nope its not the same they're different...
2018-10-11
