Special version of DJI Assistant 2 for Mavic 2 released
6929 16 2018-8-24
Wachtberger
Flight distance : 261509 ft
DJI has released a special version of DJI Assistant for Mavic 2. It installs in parallel to the general DJI Assistant for other models, thus no conflict in use.
Download link: https://www.dji.com/mavic-2/info#downloads
2018-8-24
gnirtS
Flight distance : 5712575 ft
Is it too much to hope that they actually put signed drivers in it this time?
2018-8-24
Wachtberger
gnirtS Posted at 2018-8-24 06:51
All I can say is that during installation (Win10) there was no error message concerning unsigned drivers, only a warning from Windows Defender. Not yet having a Mavic 2 I could not test more. Of course I have tested if it also works with Mavic Air, which is not the case.
2018-8-24
DannyHa
Flight distance : 259 ft
What is Dji Assistant?  I cannot open it after download because Macbook computer say it is developed by unknown developer.
2018-9-6
Wachtberger
DannyHa Posted at 2018-9-6 13:40
It is the software that allows you to upgrade the firmware in a more stable way than with your mobile device, you need it to export the blackbox data in case there is a need to make it available to DJI for warranty evaluation and you need it for calibrating the vision sensors should that become necessary one day.
I have no experience with Apple computers and therefore don't know why it doesn't work on your Macbook. Certainly others will be able to assist you with that.
2018-9-6
DannyHa
So, I can use the Window computer to do it. You meant that Dji Assistant can upgrade the firmware of Dji Mavic 2 Pro by connecting the M2P via USB cable to the WIndow computer?
2018-9-6
Wachtberger
DannyHa Posted at 2018-9-6 14:37
Exactly, but you have to use the new version of DJI Assistant that has been issued for Mavic 2: https://www.dji.com/mavic-2/info#downloads
And it is important too that your Mavic is attached to the computer and switched on during installation. In case there are any warnings from Windows Defender just confirm that you want to install all components, it is safe.
2018-9-6
DannyHa
Tks. Let me try.
2018-9-6
Wachtberger
Good luck, I believe you will like it.
2018-9-6
hallmark007
Flight distance : 9827923 ft
Hi thanks for the heads up.
2018-9-7
Wachtberger
hallmark007 Posted at 2018-9-7 09:07
You are welcome! :-)
2018-9-7
Wachtberger
You have a PM from me on the other issue.
2018-9-7
Buzzyone
Flight distance : 4647913 ft
You can install on a Mac, follow the instructions in the pop up box, you have to go into Security Preferences and tick the Install Anyway box.
2018-9-7
davidmartingraf
Flight distance : 106566408 ft
It should be good.
2018-9-8
HedgeTrimmer
Buzzyone Posted at 2018-9-7 22:41
Another way to get past it -
Do a 'Control' plus mouse click on downloaded 'DJI+Assistant+2+For+Mavic+2.0.0.pkg' file.
In pop-up menu, select 'Open with' - 'Installer.app (default).
New pop-up appears that ask to 'Open' or 'Cancel', select 'Open'.
Lastly a new pop-up opens asking for Admin login / password.
About same amount of effort as opening System Preferences.
2018-9-8
DannyHa
Thanks a lot, HedgeTrimmer, Buzzyone and Wachtberger. The upgrade via DJI Assistant has been done successfully.
2018-9-13
Wachtberger
DannyHa Posted at 2018-9-13 14:41
[view_image]
Good to hear!
2018-9-13
