New Mavic 2 Firmware Released (11/23/2023)
45106 287 2018-8-24
Shawn Patapoff
Flight distance : 6296 ft
fans98d63e0a Posted at 2018-8-24 10:12
I didn’t see mentioning if Crystal Sky monitors work with Mavic 2.  Do they?
They do not currently.
2018-8-25
DJI Susan
JohnnieYaz Posted at 2018-8-24 20:39
"DJI Goggles RE can only connect to the Mavic 2 with firmware 01.00.0600 or above via DJI Assistant 2 on a computer. Firmware 01.00.0600 will be launched at the end of August, 2018. Please stay tuned."
* Anyone see firmware 01.00.0600 release yet on assistant 2? I can't look without the RE google plugged in.
Update: The firmware v01.00.0600 has been released, please kindly check this link: https://forum.dji.com/thread-163227-1-1.html
2018-8-26
DJI Susan
fans98d63e0a Posted at 2018-8-25 06:37
Susan:  So the drone will stitch JPGs.  If I want to stitch the DNG versions...I can because both JPGs and DNGs are recorded the Mavic 2 Zoom?  Thanks!
Yes, it is. Should there is any further question, feel free to contact us.
2018-8-26
DJI Susan
forager3215 Posted at 2018-8-25 10:51
Well can say this the new DJI GO4 .24 update did fix the video lag and pixelation problem for me using samsung s7 however there are still  bugs which point to FW one the MA still drifts and doesn't like to fly in a straight line sometimes  also the drone seems to tilt  while hovering on the left side like the motors aren't  producing enough lift.
Hey forager3215, may I have some samples of the issues you mentioned in Mavic Air?
2018-8-26
RichJ53
Flight distance : 1837356 ft
DJI Susan Posted at 2018-8-26 01:33
Thanks for the update Susan.
Is it okay to run the DJI RE goggles without the  extra antenna used for analog operation? I plan on using this with Mavic 2 Pro
Rich
2018-8-26
FatherXmas
Flight distance : 4058619 ft
HedgeTrimmer Posted at 2018-8-24 12:37
Sure glad they don't sell motorcycles, cars, and trucks with Pre-production FW.
Sometimes they do. My wife's SUV has had 3 FW updates this year, one for the transmission, on for the radio/hands-free phone interface and one main computer.
2018-8-26
HedgeTrimmer
FatherXmas Posted at 2018-8-26 09:19
Sure there are FW updates to products after they are sold.
But what was being talked about was "Pre-production" FW.  Firmware that was written before the device ever went into production.  As in Beta software.
2018-8-26
BeastMaster_101
Flight distance : 1082992 ft
fans98d63e0a Posted at 2018-8-24 13:42
What about the stitching of images to get the 40+ megapixels. Is it done with RAW photos?  Or JPGs?
Most likely JPGs not sure tho
2018-8-26
forager3215
Flight distance : 230951 ft
DJI Susan Posted at 2018-8-26 01:38
Here are a few examples in video had to keep trying to nudge the drone to the right to offset the drift to left.
2018-8-26
Wellsi
Flight distance : 9082933 ft
DJI Susan Posted at 2018-8-24 23:13
Sir, there will be JPEG only for Super Resolution and HDR. Regarding the panorama, the stitched pictures will be saved as JPEG, you may choose to save the original photos as RAW or JPEG.
Thanks for the updates Susan.  And the significant update in the Original Post.
According to DHL, my Pro 2 is already on its way from SHENZHEN - CHINA....
I wonder if anyone has actually got theirs yet?
Cheers
Ian
2018-8-26
DJI Susan
RichJ53 Posted at 2018-8-26 07:20
Hi Rich, it is recommended to run the DJI Goggles with the extra antenna used for analog operation, sorry for the confusion.
2018-8-27
DJI Susan
forager3215 Posted at 2018-8-26 11:49
It seems that the video cannot play now, only the picture is available. Could you check and confirm?
2018-8-27
DJI Susan
Wellsi Posted at 2018-8-26 22:24
You are welcome. Wish you receive the package soon. Should there is any further question, feel free to contact us.
2018-8-27
WickedWingman
THIS IS SO OBNOXIOUS!
i have the mavic 2 plugged in, but assistant just keeps searching for firmware in the list.  never finds anything.
the app won't download the firmware.  it just tells me i don't have a network connection, but i do.
::edit::
well after more than a dozen reboots of both the mavic and the controller, it finally found the update.  updating now.
2018-8-27
RichJ53
Dirty Bird Posted at 2018-8-27 02:10
The external antenna included with the RE Goggles is only required for connecting to analog transmitters.  You don't to use it when connecting via OccuSync.   The digital reception antennas are built-in to the goggles.
Hi DB
The reason I was asking is, most of these transmitters / receivers need the loading of the antenna to prevent the output transistors can burn out or overheat.
Sounds lie this is not a problem.
Thanks
Rich
2018-8-27
RichJ53
DJI Susan Posted at 2018-8-27 05:10
Hi Rich, it is ok to run the DJI Goggles without the extra antenna used for analog operation, no worries.
Great, I just didn't want to damage the circuit if it was required.
Thank you!
Rich
2018-8-27
WickedWingman
RichJ53 Posted at 2018-8-27 09:11
Hi DB
not usually on the receiving side.  transmitters need a load, or it will burn up eventually.  although a lot of times, even the short pigtail to get it from the transmitter to the antenna gives enough resistance to delay burning up electronics for a couple minutes.  receivers often even require you to leave antennas off during calibration procedures.
2018-8-27
RichJ53
WickedWingman Posted at 2018-8-27 09:36
Hi WW
Thanks for the information, very much appreciated.
Rich
2018-8-27
WickedWingman
it's not often i can offer experience or knowledge in the dji forums, but i do know my way around fpv and electrical engineering.
glad to offer help when i can.
2018-8-27
droneAirly
Flight distance : 2082818 ft
Poland
Is any chance for firmware update on Mavic AIR - hyperlapse and active track 2.0 ? If not, why? I spend a lot of money this year for mavic air combo :/
2018-8-27
dari_017
Flight distance : 6016004 ft
I got my Mavic 2 Pro today, and the update on the controller and drone using the newest assistant 2 version was really smooth.
2018-8-27
PHL
Flight distance : 1044062 ft
Sure they do; Tesla updates over the air all the time, and their self driving in still coming. Otherwise most other cars have old software, usually even several years old, in the name of stability.
Personally I don't mind DJI getting a product out that fullfils my requirements, and is able to be upgraded over time. Only issue is due to the short upgrade cycle of drones, some upgrade are unlikely to come to current models; otherwise no one will upgrade.
2018-8-27
HedgeTrimmer
PHL Posted at 2018-8-27 14:14
No they don't.  Pre-production FW
Pre-production FW is equivalent of Beta Software or possibly even Alpha Software.  DOT would be all over car company selling a car to public with Pre-production FW for say Anti-Lock Brakes which might fail to apply proper braking vs. traction or lock-up entirely because driver had their turn signal on.
2018-8-27
dari_017
Dirty Bird Posted at 2018-8-27 18:05
Went smoothly for me as well.
That’s good , the only thing that was giving me trouble was the activation, for some reason it kept saying that it couldn’t reach the server connected to my house WiFi , but as soon s I did it using LTE it went thru just fine , I had this issue with other dji drones in the past , so knew what to do.
2018-8-27
dari_017
2018-8-27
Ulysses Paiva
Flight distance : 692792 ft
I´m wondering if they will simply put MP2 aside when they start to produce MP3 as they did with Mavic Air... All attention now but what about 6 months from now?
2018-8-28
WickedWingman
dari_017 Posted at 2018-8-27 19:39
i had the same issue, but even switching to LTE didn't help.
2018-8-28
DJI Susan
WickedWingman Posted at 2018-8-27 08:16
Hi WickedWingman, thanks for keeping us updated. Glad to hear the issue has been fixed. Should there are any further questions, feel free to contact us.
2018-8-28
DJI Susan
RichJ53 Posted at 2018-8-27 09:12
Thank you!
My pleasure. If there is anything else we can help, do not hesitate to contact us.
2018-8-28
DJI Susan
droneAirly Posted at 2018-8-27 12:09
Hey droneAirly, this request has been forwarded to our engineers, hope they can consider it in the future.
2018-8-28
Rob W
Flight distance : 96152 ft
Sweden
We need Cinema4K resolution on the Mavic 2.
2018-8-28
Pidge
Flight distance : 82844 ft
DJI Susan Posted at 2018-8-24 22:57
Hi there, the Crystal Sky and Mavic 2 are not compatible for now, our engineers are working on this and release as soon as it is ready. Thanks for your support and patience.
Nice to hear that this is possible.
Is there a mounting support available for  the crystalsky 7.85 " Ultra  to attach it on the transmitter?
2018-8-28
dari_017
WickedWingman Posted at 2018-8-28 03:42
Have you try restarting the drone and controller ?
2018-8-28
WickedWingman
dari_017 Posted at 2018-8-28 06:25
at least a dozen times
2018-8-28
dari_017
Maybe update the firmware for both Mavic 2 and controller using the latest assistant 2 then try to activate , that’s what I did.
2018-8-28
Auspete
Flight distance : 6939 ft
Hi Susan
I have a 5.5" Crysytal Sky monitor that I use with the official DJI mount on my Mavic Pro RC.
I also have a Mavic Air that the DJI Crysytal Sky mount WILL NOT fit the RC.
Can you please advise if the DJI Crystal Sky mount will fit the Mavic 2 Pro RC or does it have the same design problem that the Mavic Air RC has?
Also I have an original pair of DJI Goggles that only run on 2.4GH. Am I correct in assuming that when the next firmware update comes out for the Goggles that they will work with the Mavic 2 PRO.
Thanks
2018-8-28
DJI Susan
Rob W Posted at 2018-8-28 05:54
Rob, thanks for your suggestion. We'll release on our website if there is an update.
2018-8-28
DJI Susan
Pidge Posted at 2018-8-28 06:07
Hi Pidge, we do not have received such a news for now. If there is an update, we'll release on our website at the first time.
2018-8-28
BIGDZ
Flight distance : 10255860 ft
I can’t seem to find the 2day dis charge function, is there not  an option on the M2 Pro, to change  it or is it just like the Mavic Air?
2018-8-28
Rob W
Sweden
DJI Susan Posted at 2018-8-28 22:04
Thank's Susan! We have lower resolution on the newer Mavic in comparison to the older - a step down and backwards.
2018-8-28
