Battery issue
1321 14 2018-8-25
lucass34
This happens when i try to charge my battery. (only the 4th led blinks, than all lights go off, as in the video)
The battery is not hot, it rested 1 day before trying again to charge.
I also tryed to charge it overnight ,nothing changed.
Thank you!
https://drive.google.com/open?id=1N9rn2njG7_DUSf1QNdutctzk9LYsRRKj
2018-8-25
DJI Paladin
Flight distance : 318 ft
Sorry for the inconvenience. May I know when did the issue started? When you insert the battery to the aircraft, did you receive an error message on the APP or the drone will not turn on? Do you have an extra battery to use so that we can test it to the charger? Thanks for your support.
2018-8-25
lucass34
DJI Paladin Posted at 2018-8-25 06:49
Yes I have 2 batteryes, the problem appeared after I charged both of them and went flying. but only one of them worked. there was no error message for the broken one as the aircraft couldn't be turned on.
the other battery had the same issue but recovered appearently.....
I did not use the drone for a few months....the batteryes were at 50% when I first cecked them
2018-8-25
RedHotPoker
Flight distance : 165105 ft
How many charges have they each had..
RedHotPoker
2018-8-25
lucass34
RedHotPoker Posted at 2018-8-25 08:43
20 - 30 I did not use them a lot...
2018-8-25
RedHotPoker
lucass34 Posted at 2018-8-25 09:26
Yes, those are barely broken in.
Odd behaviour for sure.
I presume all of your firmware has been updated?
RedHotPoker
2018-8-25
lucass34
RedHotPoker Posted at 2018-8-25 09:39
Yes, updated a few days ago....
Thank you!
2018-8-25
lucass34
Funny thah now I have only one battery working ,and I also have problems connecting to the aircraft...
I am connecting with a huawei P10....frustrating that I have to keep restarting the AC and RC , the app
2018-8-25
lucass34
Could it be the temerature sensor?
2018-8-25
RedHotPoker
lucass34 Posted at 2018-8-25 09:48
Where are you located?
What is the ambiant temp?
RedHotPoker
2018-8-25
RedHotPoker
lucass34 Posted at 2018-8-25 09:46
Perhaps you also need a more robust device that has more processing power, for the hungry app?
RedHotPoker
2018-8-25
lucass34
RedHotPoker Posted at 2018-8-25 09:58
Eastern europe, Roamania....indoor 24C...
2018-8-25
RedHotPoker
lucass34 Posted at 2018-8-25 10:03
We are nearly on the same latitude.
That temperature shouldn’t be a factor.
Have you done an IMU and gimbal calibration recently?
Now I’m grasping at straws....
RedHotPoker
2018-8-25
lucass34
where are you from?
No I didn't do that , I will try...
Thanks anyway...
2018-8-25
RedHotPoker
lucass34 Posted at 2018-8-25 10:22
where are you from?
Thanks anyway...
I’m way up here, in Edmonton Alberta. Ca.
Sure give it a try... can’t hurt.
Good luck. I have faith it will improve.
RedHotPoker
2018-8-25
