DJI Active Track 2.0 Tests
2999 18 2018-8-25
David J.
Flight distance : 1231385 ft
Hi all
With the new Mavic 2s out along with their new/updated flight modes, I was wondering what people’s thoughts are, especially on the Active Track 2.0. It seems that it got a huge overhaul and is way better, tracking things up to 72kph and creating movement algorithms to estimate the location of it. Seems pretty crazy.
So, please share you expirence/thoughts/videos/etc. on the updated Active Track. Nothing good about it seems to be out on YouTube yet, so if you have a Mavic 2, could you test Active Track 2.0 and share the results? It seems like it could really be something!
Also, I have a priority shipping code for a Mavic 2 that I’m not going to use. DM me if you’d like it.
2018-8-25
Wachtberger
Flight distance : 261509 ft
Just one correction on this: Active Track will definitely not work at 72 kph. That is the maximum speed that M2 can do in Sport mode, but not in the Intelligent Flight Modes.
2018-8-25
David J.
Wachtberger Posted at 2018-8-25 10:31
Makes sense. But, the livestream didn’t specify how fast it would really track things - see 18:45:
https://m.youtube.com/watch?v=ctm69vb2Pf8
2018-8-25
Wachtberger
David J. Posted at 2018-8-25 12:59
This is the best source of information: https://dl.djicdn.com/downloads/ ... 20Manual%20V1.0.pdf
2018-8-25
David J.
Wachtberger Posted at 2018-8-25 13:07
It seems as though it can fly at 20m/s = 72kph = 44.7387mph. This should really push the limits of what can be done, especially if you are flying in a very open area. Check this out:
2018-8-25
Wachtberger
I might have been wrong then and this is truly amazing from a technology point of view. Nevertheless here comes my big BUT: I definitely never would try doing this ;-)
2018-8-25
hallmark007
Flight distance : 9827923 ft
They did actually say it would track up to speeds of 72kph . We shall see.
2018-8-25
David J.
Wachtberger Posted at 2018-8-25 13:24
I would only dare if the terrain was really open, or I had it above any interference. Still, very sketchy
2018-8-25
David J.
hallmark007 Posted at 2018-8-25 13:40
I’m really hoping to see some field tests to see how well it actually works. The original Active Track was a bit buggy, so tracking at max speed seems almost too good...
2018-8-25
Mikem691
Flight distance : 247474 ft
Its at about the 4 min mark in this DJI video
2018-8-25
Mikem691
Not my video but here is a good test
2018-8-26
DJI Wanda
Hi. Sorry for the late response. ActiveTrack 2.0 allows you to select an object on your mobile device screen. The aircraft adjusts its flight to track the subject. No external tracking is required. Mavic 2 pro/zoom can automatically identify up to 16 objects and uses different tracking strategies to track people, vehicles and boats.
You may refer to this manual as well: https://dl.djicdn.com/downloads/ ... r%20Manual_v1.0.pdf
2018-8-29
David J.
DJI Wanda Posted at 2018-8-29 07:51
You may refer to this manual as well: https://dl.djicdn.com/downloads/Mavic_2/20180827/Mavic%202%20Pro%20Zoom%20User%20Manual_v1.0.pdf
Thanks. It really seems like an upgrade from the original Active Track.
Now to see how it holds up in real-word testing!
2018-8-29
DJI Wanda
David J. Posted at 2018-8-29 08:04
Yes, that is correct, David. Good luck and have a safe flight!
2018-8-29
Gunship9
Real world testing where a pilot is flying the drone and letting active track point the camera/drone?  The pilot there to make corrections if the drone gets into danger?
Or, real world testing where the pilot puts away the controller, leaves the drone to its own devices, and hopes the drone will follow him while he does another task such as bicycling?  The bicyclist then ignoring his pilot duties/responsibilities while his drone is in the nation's airspace.
New RC model hobbyist, "My drone flew into a river while I was skateboarding.  Will DJI replace it?"
2018-8-29
David J.
Gunship9 Posted at 2018-8-29 08:21
Essentially either. What I want to see is how well the camera can track the object - either with or without a pilots input.
I do agree that people might find false security/have false trust that the Mavic 2 will flawlessly follow them while avoiding a myriad of obstacles.
That is a little worrying to think about...
2018-8-29
Gunship9
David J. Posted at 2018-8-29 08:29
I've seen smart modes happily keep the camera pointed at the subject but not be able to figure, or hold, the distance to the subject.  Then it can't hold position and rapidly races backwards into the distance.
Active tracking isn't using GPS to stay with the subject.  It is using the subjects position to figure out where the drone should be.  Very risky.
I have used active tracking when I first got my drone but tend to not use these days since flying manually is faster and more accurate.  Since I am a RC pilot responsible for what happens, I like to keep the drone fully under my control.
2018-8-29
David J.
Gunship9 Posted at 2018-8-29 15:08
I find the same - I’d rather pilot it myself, and get similar/better shots opposed to surrendering control to the drone.
2018-8-29
Tridiver
Flight distance : 4459344 ft
yes if you recover it!!  You'll need this!!
2018-8-29
