Leaving batteries fully charged
7768 24 2018-8-26
Christine96
Is it ok to leave the MA batteries fully charged?  I haven't flown mine is a while because I've been flying my Phantom but the batteries are still fully charged.
2018-8-26
msinger
Flight distance : 228255 ft
They should start auto discharging down to the storage level after 10 days.
How long have them been full charged?
2018-8-26
Koelkop
Flight distance : 22814806 ft
South Africa
It is not really ok to leave your batteries stored at 100%, auto discharge or not. The auto discharge should only come into play if you forgot them at 100%. It can be set from 1 to 10 days.
Store your batteries at around 60% when you are not going to use them within the next 2 or so days.
This is to extend the life of the batteries.
2018-8-26
msinger
For some strange reason, pressing the button on Mavic Air batteries does not reset the 10-day countdown.
2018-8-26
msinger
Koelkop Posted at 2018-8-26 12:50
The default setting is 10 days. Unfortunately, it cannot be changed in DJI GO.
2018-8-26
Koelkop
South Africa
msinger Posted at 2018-8-26 12:56
Is that the case on the mavic air? On the Pro I can adjust it, mine is set on 2 days
2018-8-26
msinger
Koelkop Posted at 2018-8-26 13:01
That's the case on the Mavic Air. It's what the OP is using.
2018-8-26
Christine96
msinger Posted at 2018-8-26 12:38
Probably more than 10 days but I've checked them a few times which I think resets the 10 day cycle.
2018-8-26
DJI Tony
Hi, Thanks for the inquiry, regarding the battery storage we have documentation that you may refer. Please see the image below for the advisable storage of your battery. Please don't hesitate to reach us if you need our help. Thank you.
2018-8-26
Hellsgate
Flight distance : 1991555 ft
Christine i would suggest that you manually discharge them down to around 60% then leave them alone untill you are ready to fly again ie dont press the button to check them every cple of days.
After a month or so then yes check them but if your planning on not using the drone for quite some time only recharge untill the 3rd light starts to flash then remove from the charger.
To manually discharge just simply go for a fly or let the drone hover untill battery is at around 60% then remove the battery do this for each battery.
2018-8-26
Christine96
Hellsgate Posted at 2018-8-26 15:35
Thanks I'll try that.
2018-8-26
Hellsgate
If you have had the drone for some period of time dont forget to do a deep discharge cycle prob every 6 months should be fine.
2018-8-26
Christine96
Hellsgate Posted at 2018-8-26 16:17
I've only had it a few months.
2018-8-26
Hellsgate
You will be fine just dont leave them in a fully charged or discharged state between 50 and 65 % is the best range for them to be stored in
2018-8-26
Christine96
DJI Tony Posted at 2018-8-26 14:52
[view_image]
Is there a way to discharge the batteries without flying the drone?
2018-8-27
rolling56
Flight distance : 138310 ft
There are videos on this same subject here.
2018-8-27
DJI Tony
Christine96 Posted at 2018-8-27 14:13
Hi, Thanks for your prompt reply. You can use the discharge option in the DJI GO 4 app under battery settings, you can discharge the battery depending on how long you will put the battery on the storage mode, however, the maximum would be 10 days and turning on the battery will reset the discharging process. Please let us know if you have other concerns.
2018-8-28
Atlas_Aus
Thailand
Hi all,
Newbie here... So I should not leave my batteries on the charger until next flight ? At the moment I am flying nearly every day....
2018-8-28
msinger
Atlas_Aus Posted at 2018-8-28 09:26
Hi all,
It's fine to charge the batteries daily if you're going to use them daily.
2018-8-28
Atlas_Aus
Thailand
msinger Posted at 2018-8-28 13:13
Thanks,
But I mean leaving them on the charger until I am ready to use next time ?
2018-8-28
FntX
Flight distance : 158734 ft
Atlas_Aus Posted at 2018-8-28 21:31
Thanks,
From a safety standpoint you shouldn't do that. Ever. With any rechargeable-battery powered device.
The battery will drop in voltage within a specific range in a specific time window and as soon as this is the case, the charger will start to charge the cell. This stop-and-go condition might damage the cell or at least decreases the lifespan of the battery.
Charge them and disconnect the batteries as soon as they are fully charged. Leaving them on the charger for a few hours after charging is no problem at all. But always try not to charge batteries unsupervised and always on a fireproof surface...
I had a phone battery in my hands when it went bang and I can tell you LiPo batteries are vicious little beasts!
2018-8-28
Atlas_Aus
Thailand
FntX Posted at 2018-8-28 22:11
Thanks mate.
I wasn't sure it was drone specific batteries.
I have had camera and AAA/AA rechargeable for years and have always left them on charge and never noticed a reduced life or other issue.
I tend not to plan to 'shoot' too often, so it's nice to have charged batteries waiting when I do... Though with the cost of these drone batteries I may do as you suggest.
2018-8-29
msinger
Thanks,
As @FntX noted above, it's not safe to charge batteries while unsupervised. While DJI battery fires are quite rare, you don't want to be the one to lose a house over it.
2018-8-29
djiuser_na5YlufudV5u
South Africa
Actually learned a lot reading this thread!
2018-12-16
DJI Tony
djiuser_na5YlufudV5u Posted at 12-16 12:34
Hi, we're glad that it came conveniently to you visiting our forum. I would recommend reading the manuals and safety guidelines when using the drone via our website. You may refer to the link below. Please let us know if you need our assistance. Thank you for the support.
www.dji.com
2018-12-16
