Charissa
Flight distance : 689334 ft
South Africa
By pressing GO, it starts the process. Make sure you don,t touch the sticks, it will cancel the process. Make sure your max altitude is high enough. Can not do a quikshot with a low, for eg 30m maximum altitude.
Also, if there is high winds, the quikshot will automatically stop recording, and return to starting point.
You do not need to press record. Go into quikshot mode, select the one you want, select the focus, main interest of your shot, and press go. Wait for it to finish fully, will give you a message if completed.
Thats it. Let us know if it helped. |
