Why does my P3S RTH function fail?
1150 12 2018-8-26
Jonah
return to home dosent work dont want to lose my drone
2018-8-26
msinger
Flight distance : 228255 ft
What happens when you try to use it?
2018-8-26
Labroides
Flight distance : 9991457 ft
I'm going to take a guess that you tried it closer than 66 feet to the launch point and it just landed where it was??
That's how it is programmed (and mentioned in the manual).
Fly it further away and tryu again .. a few times.
Practice cancelling RTH and resuming control too.
2018-8-26
Peterx
Flight distance : 1499708 ft
Closer than 66ft (20 meters) your bird does not trigger in to the RTH as i know.  Fly further than 50 meters(164 ft) then call it back via RTH and it does it. Find out the right height for the RTH maneuver to avoid crash with obstacles.
2018-8-26
DJI Natalia
Hi, I'm sorry for the inconvenience and trouble caused. May I know what happened when you try to use the RTH button? Please make sure that your AC must be flying above 20 meters (65 feet) when using RTH button. You can check this on Phantom 3 Standard Manual for further clarification. If you have other concern, please let us know. Thank you.
https://www.dji.com/phantom-3-standard/info#downloads
2018-8-27
Jonah
I am trying RTH at max range. Once RTH is initiated, up in the top left corner of screen an orange/ yellow triangle warning symbol appears and it says RTh failed..........  Thats it?
Any feed back is appreciated.
Thanks
2018-8-28
ALABAMA
Flight distance : 10442687 ft
Try reinstalling the GO app.
2018-8-28
Rene Jensen
Denmark
what height have you set return to home??
2018-8-28
Labroides
Jonah Posted at 2018-8-28 09:40
Thanks
Have you only tried this once?
Or does it happen repeatedly?
2018-8-28
Jonah
It is set to return home at 70 meters. Yes it has happened several times. I'll try re-installing the app and go from there.
Thanks. I'l post my findings.
2018-8-28
Geebax
Jonah Posted at 2018-8-28 21:20
This might seem silly, but are you expecting the aircraft to automatically return home when it gets 70 Metres away from you?  Or are you talking about setting the return to home altitude to 70 Metres?
2018-8-28
RedHotPoker
Flight distance : 165105 ft
Geebax Posted at 2018-8-28 21:47
I would Hope it’s the height for his drones RTH. HA
RedHotPoker
2018-8-28
Jonah
70 meters is the altitude.
2018-8-28
