mark97564
Flight distance : 2067749 ft
Everyone says the panel antennas work best but I've tried them on my flamewheel f550 and I'm lucky if i get 600ft away with a 250ft altitude before the picture will get real jittery.. then i put the wire type antennas on and I'm able to get 1700ft away with an altitude of 250ft. I have the dji landing legs on it along with the h3-3d gimble and dji gimble bracket and i mounted the panel antennas to the left rear and front right legs with the flat part of the antennas facing forward and back wards. Can someone tell me the specs on each antenna and their gains? And rubber ducky antennas ive learned are worthless with analog vtx's and that circular polaritized antennas or a patch antenna on the receiver give the best result. And I'm wondering what are some better antennas I'm able to use on the LB ground station? And how i need to mount the panel antenna on my f550 so they work better than the wire type antenna on the air unit?
Thanks in advance,
Mark |
