Spark controller with ipad mini 2 and OTG cable
2126 11 2018-8-28
djiuser_W9j5rkH5LP7m
I wonder and ask you guys that when i plug the controller with an OTG cable,to my mini ipad 2, in following the sequence:
ipad in Airplane mode
1- Start Spark
2- Start controler
3- Green light on
4- Dji go 4 turn on ipad
5- OTG cable plug in ipad
6- OTG cable plug on controller
Then i get the message"device not supported"
I just dismiss it and go flying without any problem.
AND HERE IS THE QUESTION: is the ipad mini 2 connected to the controller by the OTG or by WIFI. How could we know.
Thanks if any of you guys had ever been concern by that point let me know.
2018-8-28
Strobing_NYC
Flight distance : 3866470 ft
dude, turn the wifi off on the iPad....
2018-8-28
Strobing_NYC Posted at 2018-8-28 15:38
I should have tought about it. Since my 70s i'm getting slow.
2018-8-28
drewhoover
Flight distance : 323455 ft
To make sure the wifi is not connected from the iPad to the controller, be sure to turn the wifi off on your iPad. Let me know if you have any more problems or questions!
2018-8-28
Amikase
drewhoover Posted at 2018-8-28 18:02
Thanks to your help. This DJI forum is great because of you guys.
2018-8-28
Mimus
Flight distance : 284770 ft
Airplane mode should turn off Bluetooth and WiFi on iPad automatically
2018-8-28
DJI Paladin
Flight distance : 318 ft
Sorry for the trouble. As of the moment, OTG cable is optimized for Android devices only. You can connect your iPad mini 2 using WiFi. Let me know if you're still having issues connecting you device. Thanks for your support.
2018-8-29
Amikase
DJI Paladin Posted at 2018-8-29 02:26
Thanks for your comment.
I have some news for you.
Same settings as above:
Airplane mode
WIFI turn off
Then after getting the message "device not supported"
I dismiss it
And dji go 4 works perfectly trough the OTG cable connection. All flying mode
2018-8-29
DJI Paladin
Amikase Posted at 2018-8-29 04:31
You're welcome.  Let me know if you have other concern, we are here to help. Thanks for you support.
2018-8-29
Amikase
I dug deeper to understand how it is possible to have a connection with an OTG cable although it is not possible in theory. The way I proceed is first to connect the ipad (after the green light)to the controller  without the  OTG  cable  and with WIFI, then cut the WIFI and connect the cable. It seems that the two devices are paired and they stay connected trough the cable .
I would like to get feedback about this .
2018-8-30
QQRUCH
Flight distance : 595518 ft
Hello Paladin, any news about the use of OTG in iOS? It really works very well. I do not understand what the problem is, why so much delay in DJI certification to be able to use it.
2018-8-30
DJI Paladin
QQRUCH Posted at 2018-8-30 11:00
Hi there, as of the moment, there is no update yet about this. Rest assured that we  will keep improving our products to provide you more options when in terms of compatibility. Thanks for your understanding.
2018-8-31
