simulator compass orentation unmatch
725 6 2015-5-28
firdausyusof198
Malaysia
Hi all..I am not quite sure is it just my unit or its happened to all..I noticed my compass on my simulator is on the opposite direction.sigh..
2015-5-28
tapboxer
Flight distance : 824672 ft
check to make sure its not locked facing north, press the little compass on the map to toggle it
2015-5-28
firdausyusof198
Malaysia
Checked..the map its not lock and the orentation is back to normal when I exit simulator mode. I am running the latest version DJI pilot app. Everytime I enter simulator..the.compass orentation reverse..kindda anoying...and.I.checked with my friends inspire...it showed the same result...a reverse compass arrow...
2015-5-28
firdausyusof198
Malaysia
2015-5-28
nilsblix
Flight distance : 23047543 ft
Portugal
I also have a reversed orientation in the simulator - I have not used it much - but it has always been like that. Regardless of which FW or SW I have been using.
2015-5-28
tapboxer
I think if you look closely you see in the simulator the bird is facing you when it starts. Fly it behind you and you will see it's pointing the right way
2015-5-28
firdausyusof198
Malaysia
Yup...the bird is facing away from me when I start it
2015-5-28
