Mavic Pro 2 and DJIGo4 suuuuper laggy
12
5739 48 2018-8-28
DennisMurry08
Flight distance : 5948264 ft
I put an iPhone 6s on and the lag was gone...now I’m going to try a couple setting changes and see if I can get the iPad mini to work better...will update
2018-9-1
bomberuk
Flight distance : 16759 ft
to day the mavic pro 2 was unflyable due to excess lag on the app, ive always used my samsung galaxy s5 with no probe on the mavic 1, the new go app definitely has performance issues.
2018-9-1
fcwest
Flight distance : 73595138 ft
Decided to install iOS 12 developer beta 12 on the iPad Mini 4 and can report the lag issues have disappeared. Let's hope it lasts!
2018-9-2
Cougar1
Flight distance : 924393 ft
DennisMurry08 Posted at 2018-9-1 07:20
I am running with iPad mini 4, and have NO issues what so ever.IOS 11.4.1
2018-9-2
DennisMurry08
Cougar1 Posted at 2018-9-2 17:51
Funny you said that....I was just at BestBuy and they have the 128G on sale for $299.....now to distract the wife......
2018-9-2
MP2884
Flight distance : 23320 ft
Austria
Are there any news regarding the delays?
I also have this problems, although without recording - so this can't be a problem with the SD card.
I have delays up to 30 seconds and more :-(
I have a own phone only for flying - it's not the newest and it's not on the compatibel list, but it worked perfect before with the Mavic Pro (1).
Android 6.0
Doogee, Cortex A7 Quad-Core-Prozessor und 2 GB RAM
Thanks and regards,
Martin
2018-9-9
Bob Brown
Flight distance : 4209662 ft
Turn off video cache in GO and lower the resolution a bit. Also be sure to run the device outside of a case on hot days.. heat can cause apple devices to throttle down.
2018-9-9
Justin552
Flight distance : 17267 ft
DJI Tony Posted at 2018-8-30 10:12
Hi, Thanks for your feedback we will forward this issue to our engineers for further clarification. I would recommend turning off the wi-fi and bluetooth connection to prevent interferences as well. Please check the environment if it's recommended to use the drone. Thank you for the support.
You really are useless when it comes to solutions
2019-4-30
Skyhooker
Flight distance : 149980 ft
I have a M2P and just recently updated to latest firmware. I now have the very laggy (very, very) video feed problem. Problem did not exist with previous version. I also fly with a friend who has a M2Z and he has the same exact problem after updating his firmware. The drone is responding in realtime but the video lags way behind. I was finally able to navigate to home and land today after flying a moderate distance away. The drone had been landed but the video played the landing about 45 seconds later. This firmware update is unusable.
2020-8-1
12
