Tilt motor power problems?
843 2 2015-5-28
huerteando
Hi
In first place i want to apologize for my poor english.
In second one, i want to know if my ronin has a motor problem. I´ve balanced well my 5D but the tilt motor power goes to -10 to +20 intermittently. In a moment have -10, then goes to 5 (for example) and then to -5, end then to +20. What is hapening?. The Ronin, when this is hapening, is vibrating. I tried to re-balance and to tight the knobs but i cant stop the vibrating. If i turn lower power into the tilt motor, it stops for a while, but when i go with the ronin for a walk it starts to vibrate again. Other days i had no problem with it.
I´m doing something wrong?
2015-5-28
DJI-Cathy
Make sue the Lens support screw is mounted and the tilt is balanced well
2015-5-31
jhamelin
is your camera perfectly balanced like in this video ?
Can you put it in angle angle and it won't move
2015-5-31
